  • 1994 - 1995 Specific Tech
Are 94/95 computers interchangeable?
  • Thread starter Thread starter 88gt88
  • Start date Start date Oct 23, 2007
88gt88
37
  • Oct 23, 2007
Were there any differences in computers between 94-95 Mustang gt 5.0, 5 speed. My 94 mustang has a 95 mustang computer in it. Will this effect anything. I want to know even if it is a very small difference. Thanks
hollywoodstang
1,095
Oct 23, 2007
  • Oct 23, 2007
Nope. they are the same.
ProKiller
3,064
15
78
PA
Oct 23, 2007
  • Oct 23, 2007
as long as the car it came out of was a manual and your car is a manual or vice versa, your good to go.
5.0TailPipeHump
153
Oct 23, 2007
  • Oct 23, 2007
hmm saw this thred and had to post up, would it go in with no problems on a 93 mustang , iv herd that the 94 95 mafs are 70mm, would this be a safe move to change it over, i belive that iv got a 55mm.
88gt88
37
  • Oct 23, 2007
ok thanks guys for the info. Now my next question. the computer I have has a jet performance module attached to it. Can I just remove it or was there a stock module in there that I need to have in order for the car to run. Thanks
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 23, 2007
  • Oct 23, 2007
The EEC itself can't be swapped directly into your 93, no. I'm sure there's a way, but to my knowledge, it hasn't been done. I'm sure it's just the reverse of doing the PIH swap on a 94-95, where we use the A9* series computers in our cars, but it still requires some work.
You can remove it. There was nothing attached to the EEC from the factory.
88gt88
37
  • Oct 23, 2007
Ok now, is there a difference between the computer wiring harness's in a manual verse auto car. The reason I ask is because the car was auto and converted to stick so I want to make sure everything electrical is sound before I start doing things. Thanks again
Also, if any one has access to diagrams if there are differences in harnesses I would greatly appreciate if you could get me a link. Thanks
HISSIN50
34
129
Oct 23, 2007
  • Oct 23, 2007
Does your car have a T4 puter in it already, or is this the first time you're putting a T4 puter in the car (it was last driven with a U/W puter)?
88gt88
37
  • Oct 23, 2007
The computer thats in the car is out of a 95 gt 5.0 5 speed so im assuming its a t4mo. I cant verify this because the tag is ripped off. I am trying to find out if this was a hack job trans swap or if it was done right. let me know what to look for thanks.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 23, 2007
#10
  • Oct 23, 2007
  • #10
Its been so very long since I looked inside my pcm
but
I seem to remember a sticker inside that would tell you what pcm you got
Grady
88gt88
37
#11
  • Oct 24, 2007
  • #11
I took the ecm apart. there was no sticker inside. However there was a little circle and it said 95 inside. Im assuming this is the year right? Also, are all 5 speed computers the t4mo or are there a few different ones. Thanks
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 24, 2007
#12
  • Oct 24, 2007
  • #12
Guess my memory has failed me once again
Here you go
PCM year dates and strategies and cal file
1988-1993 Mustang = GUFB Strategy = A9L, A3M, A3M1, X3Z, S0Z
1994-1995 Mustang = CBAZA Strategy = T4M0, U4P0, W4H0, J4J1, ZAO
94-95 Stang PCM's
T4M0 = GT stick trans
U4P0 = GT auto trans
W4H0 = GT auto trans
J4J1 = Cobra
ZAO = Cobra R
Grady
88gt88
37
#13
  • Oct 24, 2007
  • #13
Ok, so that confirms that if it came out of a 94-95 gt 5 speed then it can only be the T4MO computer. Now how come the GT autos have two different computers?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 24, 2007
#14
  • Oct 24, 2007
  • #14
Some have said it has to do with the supplied rear ratio
Grady
88gt88
37
#15
  • Oct 24, 2007
  • #15
hmm, so All manual trans cars had the same rear end ratio then. Thanks for all your help by the way. I am learning alot about these cars.
fastford91
254
Niagara ,Ontario, Canada
Oct 24, 2007
#16
  • Oct 24, 2007
  • #16
yes you can put a mass air meter from a 95 on a 91 92 93 mustang they are direct plug and play! I'm not sure about older ones! the reason i know is i just put one on my 91 and yes they are 70mm!
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
M
Iac valve
  • Mike3
  • Aug 8, 2025
1994 - 1995 Specific Tech Aug 11, 2025
AeroCoupe
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
