I am looking into getting some P&P'd heads and was wondering if VT's heads are any good. I know they make kick a$$ engines and cams, just wondering about there heads.
Thanks
Thanks
Never heard anything but great results from VT as a whole. I think modulardepot.com would help you with any questions you have about VT. There is also a ton of threads about them. Search for Stage Heads or something and you will get alot of hits.Jesus said:I am looking into getting some P&P'd heads and was wondering if VT's heads are any good. I know they make kick a$$ engines and cams, just wondering about there heads.
Thanks
Indiana said:Nick. Stop goofing around and buy a KB.![]()
steeda46 said:Is it a better deal to purchase aftermarket heads or get the stock heads P/P? (Cost and horsepower gain) I found a place here in GA that can PP your stock heads for $750.00.
How much can you gain from a PP job on a NA engine?
ChadS98GT said:what about patriot compared to VT?? I know the patriot heads are supposed to be pretty good and they seem to be about 700$ less....for just about the same flow numbers...![]()
nickthegenius said:As far as my getting a KB above, I would love to, but it looks like I will be staying NA for quite some time due to upcoming tuition for grad school.
nickthegenius said:Patriot has been earning a bad reputation both from Modular and LS1 owners. They have had problems with exhaust seats falling out. Then, the valve gets stuck open and blamo!!!! There goes a piston. They are also using Chinese parts in their heads and although I'm not a big "Buy American" person, I don't want Chinese parts in my heads. Chinese valve stem caps or Chinese floor mats would be fine, but not precise and fast moving parts inside my engine.
There are no aftermarket heads. What you can buy is different companys port and polishing of stock pi heads. several company's out there doing it. I would buy cams that the company you are buying the heads from recommends to go with their heads. I chose VT heads and cams, and they are a good combination, but there are others out there. research well.steeda46 said:If P/P the stock heads vs. purchasing aftermarket heads are relatively the same. Is there any disadvantage to P/P the stock heads? It seems to be more cost affective!
Also, can you someone recommend a good cam to run with the fresh heads? I'm probably going to stay N/A and my car is not a daily driver.
