Are these transmissions any good? Because they are in the T-5 case, are they weaker?
Pokageek
2,767
MA, USA
Also, anyone find any cheaper options?
http://www.mach1registry.org/forums/showthread.php?s=&threadid=21744
CUSTOM-BUILT G-FORCE T-5 TRANSMISSIONS-
Astro Prepped/G-Force T-5 with Helical Cut/Synchronized $1,595.00
2.95 1st Ratio Gear Kit, .59% Overdrive, Stock 28 Spl.
Mainshaft, All Steel Bearing Retainer, 7T Speedometer
Drive Gear, Cluster Support Plate, and Complete
Overhaul Kit with Synchronizer Rings. These transmissions
are priced to sell, and can hold up to 600HP!
the internals are good, but yes the t-5 case is a little "weaker" when compared to tremecs. but you wont run into problems unless you make ALOT of power.
It also depends how you drive it. I have a freind that blew up 3 tremec 3550's and shot the mainshaft out of a rock crusher:eek:.
