I have been wondering this for some time now so I decided to ask. I have a breather on each of my valve covers and for some reason I think its a vacuum leak. It been heard getting the car to idle. I thought this may be one factor.
One can either use breathers or a PCV but should not use both.
If only breathers are used (no PCV), this works alright.
Or the stock PCV plumbing works for most NA combos. Because PCV is active (vacuum is pulled on the crankcase instead of just venting like breathers), PCV allows greater efficiency.
Anyhow, run one system or the other but do not mix them.
Good luck.
Good luck.
