• Community Forums
  • Regional Forums and Event Information
Arkansas Thread
  • Thread starter Thread starter GT 5spd
  • Start date Start date Oct 6, 2005
  • 90
  • 91
  • 92
  • 93
  • 94
  • 123
First Prev 92 of 123 Next Last
347lxvert
135
Russellville, AR
Feb 13, 2006
#1,821
  • Feb 13, 2006
  • #1,821
5spd GT said:
Oh was that you in the white foxbody lx vert?
What is the rest of your combo with that 347? heads? cam? intake?
Cam -- i have no idea
head -- performer
intake -- tfs street heat
24 lb injectors
AOD
jasonh_86
I
May 20, 2005
1,156
Arkansas
Feb 13, 2006
#1,822
  • Feb 13, 2006
  • #1,822
5spd GT said:
Jason - I'm waiting for you to try to get that 10.99
QUOTE]
Don't worry.. It's coming
I went retarded and forgot how to launch, couldn't pull better than a 2.1 60ft, however I still managed an 11.35 with that. I just need to get my skills back and it'll be there.. 10.97 is what I think it'll be.. If i had some 4.10's and LCA's, I think it'd help me out a little bit on getting there haha, but i'll make it work with what i've got for now.. The GS-D3's are ****ing awesome out there for traction, not really much of an issue in 2nd.. no barking/chirping in 3rd anymore, even when I powershifted it I love those things
Speaking of 10's, I can't wait to see Daniel's NOVI run out there.. that mother is gonna be BBAADDD after he gets it tuned! MMMMMMMmmmm Novi.. Doesn't get any better than that in the centri world
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 13, 2006
#1,823
  • Feb 13, 2006
  • #1,823
head -- performer
24 lb injectors
AOD
Thanks,
Thats interesting...that car should run quicker than that (both E.T. and mph) if it had a 347. Do you know it has a 347 for sure
24lb injectors is a bit small, usually "set aside" for h/c/i combos.
Jason - Yeah, if you can get some good track prep like that one day...you'll get on down there I was impressed Matt ran 11.2's. 373's, prochamber, catback, 85mm MAF.
C
cctinnell
135
Arkansas
Feb 13, 2006
#1,824
  • Feb 13, 2006
  • #1,824
head -- performer
24 lb injectors
AOD
I think your car will really wake up with your new gears. You have to remember that you have stock 2.73's and your going with 4.10's. Also, your car is a convertible so it is heavier. Also, the 347 is low compression and is set up for a power adder. You'll be fine with some gears and juice.
347lxvert
135
Russellville, AR
Feb 13, 2006
#1,825
  • Feb 13, 2006
  • #1,825
yea, the 2.73s dont really help that much, it is just aggrivating i guess, i can smoke the crap out of the tires but it takes it forever to wind up on the track with those freaking gears i barely have to shift into 2nd, clay shifted into second when he passed me at the 60 ft mark. cant wait to get the gears in and the juice, oh yea and i am sure it is a 347, the motor originally had a vortec s trim on it, but like a retard i sold it before i ever even ran the motor b/c i thought i was going to put the 347 in a 67 mustang, my how things change so much!!
RADIALKILLER
141
Arkansas
Feb 13, 2006
#1,826
  • Feb 13, 2006
  • #1,826
347lxvert said:
yea, the 2.73s dont really help that much, it is just aggrivating i guess, i can smoke the crap out of the tires but it takes it forever to wind up on the track with those freaking gears i barely have to shift into 2nd, clay shifted into second when he passed me at the 60 ft mark. cant wait to get the gears in and the juice, oh yea and i am sure it is a 347, the motor originally had a vortec s trim on it, but like a retard i sold it before i ever even ran the motor b/c i thought i was going to put the 347 in a 67 mustang, my how things change so much!![/QUOTE]
even with the stock gears you should still not even be close to finishing the 1000 ft. in 1st gear. Were you manually changing the gears?
Cantslowdown
502
Mt.Home AR!
Feb 13, 2006
#1,827
  • Feb 13, 2006
  • #1,827
Guys with the 4.6s have ya'll read the things about us having spark plugs blowing out..Man that scares me cuz right now my car makes ticking sounds...Sounds like the injectors but still cuz they say thats the first sound of a spark plug working its way lose... I hope mine is fine i havent done my tune up yet so.. Might have my work do it for me but then i got to pay them but if anything is worng my worranty will cover it so.. But tmw I am going to let a tec look at it so.. I hope she is fine!!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 13, 2006
#1,828
  • Feb 13, 2006
  • #1,828
Yeah, something ain't right with that...what mph were you running...I forgot.
You got a potent combo though for sure Something is 'amiss with that combo...
88GT460
338
Arkansas
Feb 13, 2006
#1,829
  • Feb 13, 2006
  • #1,829
So change the plugs and wires ? Not that hard.
347lxvert
135
Russellville, AR
Feb 13, 2006
#1,830
  • Feb 13, 2006
  • #1,830
i was manually shifting, i shifted at about 5200, i dont know what was up, i held it to the floor until it got to 5200, i dont know what could be wrong, i finally got the idle half way straightened out, my top speed was 81
Cantslowdown
502
Mt.Home AR!
Feb 13, 2006
#1,831
  • Feb 13, 2006
  • #1,831
I dont have wires i have coils... I was but now reading it all if i have a problem and i changed the plugs my worranty company might not cover it..
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 13, 2006
#1,832
  • Feb 13, 2006
  • #1,832
What is your timing set at? Fuel pressure? (I would put it somewhere in the mid-40's with a 347 with h/c/i). What kind of plugs and at what gap?
Your running stock 5.0 times...and you and I know its got much more in it
Run autolite 3924's gapped at .045, run timing around 16*, make sure you got correct valve lash (i'm sure it is or it would be running rough)...
Good Luck!
347lxvert
135
Russellville, AR
Feb 13, 2006
#1,833
  • Feb 13, 2006
  • #1,833
i dont have an adjustable fuel pressure regulator and i am not sure what brian set the timing at, i still have the stock regulator on there, maybe that is part of the problem, i just dont like my car running like crap, i know it has a lot more in it that what it put out yesterday
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 13, 2006
#1,834
  • Feb 13, 2006
  • #1,834
The stock regulator is set at 39psi with the vaccum line off at warm idle. The computer likes to see 38-40psi ideally...but with 24lbers I would up the pressure to the mid-40's. I don't really think that is the entire reason...weird
Yeah I know it does too...you'll get it man...
347lxvert
135
Russellville, AR
Feb 13, 2006
#1,835
  • Feb 13, 2006
  • #1,835
it has low compression so i know it wont keep up with clay all the way, but man he spanked me when we raced yesterday, he just took off like crazy, good job, bub, hopefully i will be able to get er tuned up a little better and we can race again.
C
cctinnell
135
Arkansas
Feb 14, 2006
#1,836
  • Feb 14, 2006
  • #1,836
Whenever I had that AOD in my car with 4.10's I was in 3rd when i finished. You just need your gears, fuel pressure, nitrous, and timing adjusted and it will run hard.
88GT460
338
Arkansas
Feb 14, 2006
#1,837
  • Feb 14, 2006
  • #1,837
Oh, well neither one is hard to change. You'll pay some bucks to have someone do it for you though.
Cantslowdown
502
Mt.Home AR!
Feb 14, 2006
#1,838
  • Feb 14, 2006
  • #1,838
The tecs say it sounds great.. They said if i had the problem it would sound like a bad exaust leak and it wouldnt run good.. And I would have bad mpg.. Cuz i get like 140 atank and thats at half with my right foot lol!
C
cobra_mobile
75
Russellville Arkansas
Feb 14, 2006
#1,839
  • Feb 14, 2006
  • #1,839
Whats up Clay
C
cctinnell
135
Arkansas
Feb 15, 2006
#1,840
  • Feb 15, 2006
  • #1,840
cobra_mobile said:
Whats up Clay
I am glad I got to run my car due to the fact that I have to go back to Florida next week. I really wanted to hook the nitrous up but I guess that will have to wait. Have you decided on a power adder yet?
  • 90
  • 91
  • 92
  • 93
  • 94
  • 123
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
M
Inheriting (and likely restoration of) a 1965 Mustang
  • miniwheats235
  • Feb 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 19, 2026
Realmongo
  • Community Forums
