arp head stud torque specs
  • Thread starter Thread starter BOWTIEKILLR
  • Start date Start date Jun 19, 2006
BOWTIEKILLR
100
  • Jun 19, 2006
my dads buddy is just putting our motor back together and was wondering what the torque specs are for the fine head studs. anyone know where i could find that?
Don Fiveolio
85
Houston, TX
Jun 19, 2006
  • Jun 19, 2006
Go to your local parts store and pick a Haynes or Chilton Manual. It will have the torque specs for damn near every bolt in the car. Be sure to follow the corect torquing sequence for the top end. The ARP kits bolt to the same torque as the stock I believe. The benefit over stock is that they are far stronger and can take a serious pounding. Anyone feel free to correct if I am wrong on something here.
Good Luck
Oh yeah, don't forget the thread lock.
C
COP TZER
25
VA
Jun 19, 2006
  • Jun 19, 2006
ARP isnt the same as stock.
Check ARP's website.
Its 100-110 on 1/2 studs and i believe its 80-90 on 7/16.
To be sure check their site.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 19, 2006
  • Jun 19, 2006
i was told not to use lock tite or any thread locker on head bolts, heard of head bolts snapping when attempting to remove them....
R
R2D2
Jun 19, 2006
  • Jun 19, 2006
never use a thread lock on a head bolt, ever
Stroked88
42
Jun 19, 2006
  • Jun 19, 2006
They list two different torque values depending on whether you use engine oil or the ARP lube when you torque them down. I recommend ARP lube since its a better lubricant and torque values are lower because of it. I'll try to make a mental note tomorrow of checking of the instruction sheet tomorrow when I am in the garage.
Don Fiveolio
85
Houston, TX
Jun 19, 2006
  • Jun 19, 2006
OH Snap, they' re right. Just popped openthe ARP kit and the sheet reads as follows:
Torque values are based on 75% of the fastners yield strength. Use the manufactuers torque sequence but do not use the manufacturers torque specs. Torque the bolts to 65 Ft. lbs. with 30 wt ARP MOLY ASSEMBLY LUBRICANT (or ARP THREAD SEALER) or torque to 85 Ft. lbs. with 30 wt motor oil.
My bad for the misinformation. Work boredom makes me do strange things.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
