  • 1994 - 1995 Specific Tech
ARP HEAD STUDS?
  • Thread starter Thread starter haulbalz
  • Start date Start date May 20, 2004
haulbalz
448
  • May 20, 2004
Do i need to put a sealer on te studs before i screw them into the block?
4Jenna
4,326
AZ
May 20, 2004
  • May 20, 2004
I didn't.
I just put anti-sieze on them
haulbalz
448
  • May 21, 2004
anyone else?
94TURBO5 O
2,509
VA
May 21, 2004
  • May 21, 2004
I used ARP assembly lube on the top ones and ARP thread sealer on the lowers. I just did it last night so we'll see how it holds. First time with the heads off and on.
haulbalz
448
  • May 22, 2004
why did you use the sealer on the lowers and not on the uppers?
94TURBO5 O
2,509
VA
May 22, 2004
  • May 22, 2004
I did it per ARP directions that came in the box.
Y
yellow1995Cobra
2,959
Massachusetts
May 22, 2004
  • May 22, 2004
The lowers dip into the coolant passages. Thats why you need to put sealer on the lowers. Be sure to use the ARP moly lube and sealant.
M
mcvey90
950
B TOWN
May 23, 2004
  • May 23, 2004
ARP
moly lube and sealant from arp is what I went with.
Haven't had any problems yet.
haulbalz
448
  • May 23, 2004
i guess that's my problem then... I didn't seal them and i was leaking coolant into my oil... thanks for the help guys
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
