You are absolutely correct. I was having a blonde moment. That's what happens when you add a statement to CYA and it backfires.This must be cleared up............the length of the connecting rod has NOTHING to do with displacement, period. ONLY bore and stroke make up the differences in displacement. Rod length only effects relative piston speed and dwell time of the piston at TDC and BDC. I can make a long rod 302 by moving the piston pin closer to the top of the piston, and I can make a 302 with a short rod by moving the piston pin further down from the top of the piston. In both cases, the 4" bore and 3" stroke determine that it is indeed a 302 cid engine.
Back in the day, folks said BIG BLOCK or SMALL BLOCK to differentiate the physical characteristics of the engine you were using. Not internal characteristics but EXTERNAL. So folks were on the same page as to what cross member, bell housing, exhaust, etc., that was needed to mate up to the engine block. It had nothing at all to do with internal displacement... and then there were mid-blocks.
Didn't I just say that? Stop plagiarizing me.
has anyone ever looked at actual block size as mentioned above ? because that's what I have always gone by
PPShaaw! Way!Wait... So now you're accusing me of actually READING your posts???
As if...
I like your style !I go by number of spark plugs.
