ATTENTION: metroplex rear axle moan update
D.Hearne
11,730
south louisiana
I added a full bottle of Friction Modifier to the 06 Stang's rear two weeks ago and. WA-LA................... Axle moan is gone...................... :nice: Looks like that's exactly what Ford left out of the rear gear lube................. Someone undoubtably thought it would save money, but ended up causing a problem instead.:notnice:
How does this affect the gear lube level in the axle housing? I've got an 07 with a moaning rear end....
-Jason
Is it a moan when cornering at low speeds? Or a whine at highway speeds? Moan in cornering is the Traction Loc clutches slipping, letting the inside axle turn at a different speed than the outside axle.It sounds like two objects rubbing against each other. A whine at highway speeds would be gear related (ring and pinion)
I have the latter, a whine at highway speeds... Thing has less than 1000 miles on it... Do you think there is something wrong?
-Jason
Yea, I'd at least check the oil level in the rear. Not the first time that was forgotten at the factory.:rolleyes: And adding a 4oz bottle of friction modifier will not over fill it. I filled mine till the oil was coming back out the hole.
Ok, so today on the way home I REALLY paid attention to the noise. Cruising say with cruise control on, VERY LITTLE whine... However, I do notice a whine when accellerating slowly. I mean if i had any louder exhaust I may not even hear it...
Thoughts?
You can hear some whine as it's accellerating. I know mine does if I pay attention to it. 12,000 miles and no gear problem.
I'm starting to think it may be just fine. If it was a gear installation problem, I think that I'd hear it all the time and not just on acceleration. Right? Especially with my paranoid observation on my drive home from work today...
-Jason
