auburn pro/31 spline axles
I just got an auburn pro diff and moser 31 spline axles. can i use new stock axle bearings and also can i re use my c-clips? I am really eager to put this in. one more thing, i read in another thread that it is possible to have a vacuum leak if the iac isn;t workin properly, mine is new and wont work, car idles perfect, i have adjusted the throttle plate screw and it still wont work (iac), so how can i find out if i have a vacuum leak? i have the trick flow street heat upper and lower, edelbrock 65 mm t-body, it ahs done it since then. I have tried the carb cleaner around the gasket area, no problems at all. any ideas are greatly appreciated. thanks
nick
one more...where can i get the ramcharger electric cooling fan???
When you say it "won't work" do u mean the car won't start / idle... what's your timing at?? If it's too far advanced or retarded (can't remember off hand which), then I believe the car would run without the IAC but not with. Just throwing this out there... good luck.
Jason
i have my timing set at 14 degrees, the car runs good, but it just doesnt use the iac. If i unplug it nothin happens. I have tried the whole throttle plate screw, backing it out all the way and all, nothin works. so i have just left it for now. Like i said the car runs pretty good, it just bothers me and i am very picky about stuff. thanks
nick
You car idles with the IAC unplugged b/c you either have a vacuum leak or the throttle plate stop screw is holding open the throttle. If the car runs ok then don't worry about it. My car runs with the IAC unplugged b/c I have it set like that. This way the car will not die like a lot of mustangs do once they are modified.
