I purchased a Rockfor Fosgate power Bd 1000 as well as a power 551X they have been working flawlessly for a while now....the other day i pulled out of my driveway with the radio at a normal level and went approx 1/4 mile and i noticed a burning smell i cut the car off and popped the trunk....my kicker solobaric L7 burned out. i pushed the cone in and out and i heard a cruching noise...i disconnected the sub. and removed the speaker leads off the amp. so i could still listen to the interior speakers.i turned the car back on and seconds later i smelled the burning smell again ...i cut the car back off and check the amp..i burned my hand on the heatsink on the amp.... so i know it had to have been the amp that burned up the sub.Im surpise because the fuse didnt pop.i yanked out wires and just left the power,ground and remote wire connected. I turned the key forward and the protction led started blinking and making a weird noise. I do not know what to do. I thought it could have been the ground wire because it sparked when i cut the amp on...i cleaned the surface where the wire was connected and made it nice and tight its still doing the same thing.each amp has its own ground wire and rem wire.In 5 years this is the only prob ive had with a RockFord Fosgate product...I always recommend and install this same setup in all my friends cars.
i have a 75 amp alt keeping up at 12.8 volts at max volume i need help!!!
