Aussie break-in procedure
I was in Australia last month and drooled over their fabulous Ford Falcon 4-door sedan with the 5.4-litre modular V8 engine and 18-inch wheels. I noticed a few things: (1) it comes from the factory with 0W-40 fully-synthetic oil, and (2) it has some rather different break-in procedures printed on a tag hanging from the mirror.
I'd appreciate some comments on the break-in procedures. This is what the tag says:
Ford Performance Vehicles recommends all customers use the following procedures for the ultimate performance and protection of the Boss 290 V8 engine. (For non-Aussies, the 290 indicates 290 kw as a measure of engine HP. The 2005 Mustang GT 4.6 translates into 225 kw).
In the first 750 km (about 400 miles) of travel:
* Avoid exceeding 4500 rpm
* Accelerate positively where appropriate in all gears
* On long stretches of travel, vary engine speeds by occasionally using lower gears while maintaining a constant speed, when safe to do so
* Where possible, apply high engine loads for short periods of time by using high gears at speeds below 60 km/h (40 mph)
While driving between the first 750 km and 1,500 km (about 800 miles) of travel:
* Progressively increase engine speeds up to 5500 rpm with occasional use of full-throttle acceleration while remaining within the legal speed limits
What do you think? Would this advice be good for our 4.6 motors? My new GT convertible will be here soon (build date: May 16).
Sounds like the break in procedure for a sport bike, most import advice it would seem is to vary the engine load on any trip of distance and not beat the tar out of it till it has a few miles on the clock.
Usually 2-3 cold ones will break in any Aussie !!!
As for the car procedjure, it is about what I use too.... Vary speed, use a lower gear here and there, and do not over Rev for first 1000 miles. I too change oil at 500 at 1500 miles.. then at 3000 miles and at 3000 miles there after.
