Auto Dimming Mirror
TomzGT
28
Delray Beach, FL
Is it possible to convert the regular day/night mirror to an auto-dimming mirror? If it is, where can I find one? Thanks!
yes possible, to know how much trouble, first thing is to check the wiring diagrams for your model/year to know the nearest point where the signals are that you need. Ford normally wires up everything to the main connectors behind the dash, but then the last segment of wiring to the mirror is different. If you are lucky everything might be available in overhead light console. You probably only need +12V power. The mirror normally also gets the reverse signal so that it disables the dimming while in reverse. What's the year, trim/options of your car?
I put a Gentex mirror from a nissan in my fox. Auto-dimming, homelink garage door openers, compass, and outside temp
