Auto guys...suggestions?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Mar 9, 2009
First Prev 2 of 2
white 89 GT
281
Tacoma
Mar 12, 2009
#21
  • Mar 12, 2009
  • #21
If you talk to silverfox at click click racing forums he will hook you up with the valvebody for any application you want.
The lockup or non-lock is your choice, your stock AOD is a lockup meaning 3rd and o/d the convertor locks up for 1 to 1 like direct drive.
So if you want to keep the rpm`s down on the freeway and retain some gas mileage or run say 4.10`s stay lockup with 2800 to 3200 stall.
With 3.73`s some cam for good 6k to 6200 power you could go nonlock with say 3000-3200 stall and not run out of rpm`s at the finish line.
TrickFlowd
240
Sayre, PA
Mar 15, 2009
#22
  • Mar 15, 2009
  • #22
I don't drive the car much...
I will eventually be doing the trickflow top end kit (most likely this winter) so should I go with a non lockup unit?
white 89 GT
281
Tacoma
Mar 15, 2009
#23
  • Mar 15, 2009
  • #23
Well I had my 89 setup as non lock 2500 stall with 3.73`s and bolt on`s with small cam (crower 15511) had one of those p o s chinese intakes and it ran best of 13.27/ best mph 104 with bfg r/ta street tires. My shift light would come on at around the 1000' mark and the engine just did`nt have the rpm`s needed to pull all the way across the line.
Now if I would have had the lock up convertor I would not have ran out of my power range in 3rd but when going from 2nd to 3rd the rpm`s would have dropped more, bogging the engine down a little.
My car need a bigger cam but then it would not have passed emissions.
So I bought an 80 put on the 85 gt front and rear (for looks) and then sold the 89 gt, no more emisions no more electronic crap.
First Prev 2 of 2
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
C
Drivetrain Need assistance
  • ChrisPBacon323
  • Dec 7, 2024
Fox 5.0 Mustang Tech Dec 30, 2024
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
