  • SN95 4.6L Mustang Tech
Auto Shifter trim removal ?
  • Thread starter Thread starter Outlaw97GT
  • Start date Start date Feb 13, 2006
Outlaw97GT
234
Redneckville, Tx
Feb 13, 2006
  • Feb 13, 2006
I ordered a speed-cal from DM to fix my speedo with the 4.10's..
How do I take the trim off around the shifter to mount the speed-cal?
Any auto ppl that have done this, any advise?
Thanks..........
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 13, 2006
  • Feb 13, 2006
It just pops out. Please return the speed cal and get a handheld engine programmer, thanks
Outlaw97GT
234
Redneckville, Tx
Feb 13, 2006
  • Feb 13, 2006
The SCT2 doesnt fix the speedo on 96-98, only 99+.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 13, 2006
  • Feb 13, 2006
Oh yeah...
When you pop that bezel out be sure the clips do not go flying. Slow steady pressure will help minimize that. Using an actual trim removal tool is good also:
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Feb 13, 2006
  • Feb 13, 2006
it's best if you get a removal tool so that you dont damage anything
nyuk98gt
1,427
Chesterfield, MO
Feb 14, 2006
  • Feb 14, 2006
Outlaw97GT:
The bezel, as it is called, has some plastic fingers and there are metal clips on those fingers. These clips snap into holes in the console. There are two fingers at about 7 and 5 o'clock. I can't remember where the other ones are, though. Slip your fingers under the inside opening of the bezel and gently rock it up. You'll feel resistance from the metal clips but the bezel section should come straight up. Once those two connectors are free, you gently tug at the remainder, supporting the bezel with both hands. Remember that the cig lighter has a wire connected to it (it is a bullet, snap-on type connector) so be careful that you don't yank too hard on the red wire. Once the bezel is free, you can disconnect the cig lighter wire (it pulls straight off).
There are 4 bolts holding the shifter assembly to the floor hump of the car. Be careful when you get these loose because they can easily slip between the carpet and the floor pan and it's hard to retrieve a lost bolt! Keep a telescoping magnet handy (you have one, right?). There are the "folded stamped nuts" that slide over the hole in the floor for each bolt. These nuts can get out of place so just watch you don't lose them once they are loose.
I found that the best place for the SpeedCal harness was at 12 o'clock. The box itself will sit at about 1 o'clock in between two plastic fins inside the console. Very tidy.
When you have the wiring all done, you can re-install the shifter console. Do not tighten the bolts excessively because you can pinch the SpeedCal harness and that's bad. Snug down the bolts enough so that you have about 1/16" gap between the top of the shifter console and the bezel. This requires trial-and-error fitting (putting the bezel back on and taking it off to make another half-turn on the bolts) but you want it to look good.
Use the blue splice connector but gently close it with a pair of pliers. Just don't crush it to bits. You want the connector to bite through the insulation and click together snugly for a tight connection.
That's all the free advice I can offer. Good luck.
Chris
Outlaw97GT
234
Redneckville, Tx
Feb 14, 2006
  • Feb 14, 2006
Thanks Chris, that is some great info............
I sell auto parts. so the tools are no problem. I just didnt want to break anything, all plastic parts.
The speed-cal looks pretty easy to wire up, can't wait to have the right speed reading again.
Im going to install it this weekend when I install the o/r H-pipe.
Thanks again on the install tips.
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
  • Gulftown980x
  • Jul 29, 2026
squeak93
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
