the swap isnt hard at all.
the hardest part is the pedals. it seems simple and actual IS, but its cramped as a mother ****er and all sorts of stuff that pokes and cuts your hand.
save your self the hassle and buy the alum quadrant early and put it on the pedals b4 u put then in the car, i waited and changing quadrants out in the car isnt fun at all.
some tips for the pedal install.... remove the drivers seat, its all in the way bad, also take out the center console, you have to cut the hole in the floor bigger anyways so make it easier for yourself. and while ur at it, take the passenger seat out also. deep clean the seats and really shampoo the carpet, keeps u busy in case u get real pissed or tired or the t5 swap, or waiting for parts or something.
other than that its just as easy as doing a clutch job. aod out, remove aod flexplate and put flywheel and clutch in, easy as pie.
good luck
