  • SN95 4.6L Mustang Tech
Automatic gear's help
  • Thread starter Thread starter dusty430
  • Start date Start date Apr 6, 2005
D
dusty430
31
  • Apr 6, 2005
Hello,
When I bought my 01 mustang Gt w/automatic. I seen that the diffrential cover was replaced. With this in mind, I was wondering if the gears have been swaped in my car. I have 20" rims in the back and 18" rims in the front. Tire size is 245/40ZR20 in the back and 245/40ZR18 in the front. I was driving at 75 mph at 1700 RPM however my speedo is off by 5 mph due to the tire size. I was really going 70mph at 1700 RPM. Any help would be highly appreciated because I want to put 4:10 in but I don't know what I have.
Thanks,
Dustin
CanadaStang
2,093
Mb
Apr 6, 2005
  • Apr 6, 2005
this should help:
http://www.allfordmustangs.com/Detailed/636.shtml
D
dusty430
31
  • Apr 7, 2005
I am still confused this is my results
Your Rear Gear Ratio is : 2.0035 (Toploader or C4)
Your Rear Gear Ratio for OverDrive is : 3.0053 (T5 or AOD)
I thought that stock was 3.13?
Why am I so low?
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Apr 7, 2005
  • Apr 7, 2005
why such big wheels? only 245s on those things
jeffnoel
1,638
Clovis, CA
Apr 7, 2005
  • Apr 7, 2005
dusty430 said:
Hello,
Thanks,
Dustin
You've got it backwards a taller tire means your speedo is reading low not high, so when your speedo says 75 your actually doing 81 if your speedo was recalibrated for the 20s. But with a tire 2" taller than stock I wouldn't believe what your speedo says at all. The easiest way for you to check what gears you have is to raise the rear off the ground and rotate a tire 1 full turn and count how many time the driveshaft turns. What does the diff cover look like are you sure it's not stock?
D
dusty430
31
  • Apr 7, 2005
I used one of those on the side police scanners to tell the speed. It is always 5mph faster. The cover isn't black. Ill try what you said
Cobra Jay
889
Motor City
Apr 7, 2005
  • Apr 7, 2005
The covers aren't black from the factory, they come in a natural or zinc plated finish.
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Hit something exiting
  • Creomod
  • Mar 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
General karthief
