  • 1994 - 1995 Specific Tech
automatic tranny problem?
  • Thread starter Thread starter amplifier28
  • Start date Start date Sep 20, 2008
amplifier28
222
  • Sep 20, 2008
i have a 94 stang gt vert with an auto tranny with 130,000 miles. my tranny always shifts a little hard when it shifts from first to second. what could be wrong? could it be a tranny soleniod, needs an oil change, or something wrong internally? suggestions greatly appreciated. thanks in advance!
HISSIN50
34
129
Sep 20, 2008
  • Sep 20, 2008
The 1-2 accumulator might have a broken spring - it was an issue. The accumulator itself was also redesigned and improved in later years. If you remove it to inspect it, I'd replace it with an upgraded unit. They're cheap.
Good luck.
toyman
1,944
54
79
Vernon BC
Sep 20, 2008
  • Sep 20, 2008
Something new? Perhaps the previous owner installed a shift kit.
amplifier28
222
  • Oct 4, 2008
where is the 1-2 accumulator located on the tranny? is it located on the exterior of the tranny? where would i be able to buy an upgraded unit? cost?
HISSIN50
34
129
Oct 4, 2008
  • Oct 4, 2008
I'm not saying that it is a 1-2 accumulator issue, but it is something to keep in mind and I would certainly check it if you have the pan off. All you need to remove is the pan and filter to access the accumulator. Check out this link. About 1/3 down the page is where he shows the accumulator.
I used a 6" C-clamp to hold the accumulator in place - you NEED a good pair of snapring pliers to get that big monster out and back IN (I paid about 17 bucks for a decent set of pliers, for instance. Well worth it). There's a lot of tension in the snapring.
The newer accumulators are designed to not eat the bore, so that's a nice upgrade, as are some fresh springs (dont leave a spring out, as some people like to post. Most of those guys end up replacing the spring after awhile anyhow). The accum and springs are not expensive if you dont get them from your dealership (even then, you should be able to get the accum and both springs for under 100 bucks). Bulkpart.com has decent prices - I've ordered from them before.
The other thing that's easy to swap is the shift solenoid pack. And they are not too pricey either (25 bucks or so from Bulkpart IIRC). Lastly, get a rubber over metal trans pan gasket. It's worth 5 times its cost (about 10 bucks IIRC) compared to those crap rubber or cork gaskets you get with a trans filter. Oh, get a new end cap thingie (it is what sits against the snapring. It has a seal and is cheap. They get torn up).
Here's a blow up diagram
Another article with pics that might help
I should have noted that with those articles, you're not doing all that work - just go to the parts about swapping the 1-2 accumulator. The pics and narratives were helpful to me.
TCCoA and clickclickracing.com are two great places to search for AODE/4R70W trans info, if you want to put up a thread or search for more info based on your symptoms.
Good luck.
amplifier28
222
  • Oct 4, 2008
i want to install the entire 1-2 accumulator assembly including the piston, springs and reatainer(cap). what are the part numbers that i need from bulkpart.com? what are the part numbers from the ford dealership? what would be the difference in price?
amplifier28
222
  • Oct 4, 2008
i have an 1988 mustang gt that has the same issue when it shifts from 1st to 2nd gear. the car has an aod tranny. could it also have the same problem. does it also have a 1-2 accumulator assembly?
amplifier28
222
  • Oct 5, 2008
anybody?
C
1992 LX 2,3, automatic problems, oil dissapears.
  • Carpimp
  • Aug 10, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Aug 10, 2025
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
