How does the computer derive the TP values on the X scale of the transmission functions and tables? If it makes a difference, I have a CBAZA computer with a U4P0 calibration.
I am trying to determine if my 4R70W does not shift into 4th because the TP values the computer comes up with are higher then the shift points on the 3->4 shift schedule.
FWIW, I am also going to put a switch on pin 41 to make sure that no voltage is applied to it (effectively disabling the overdrive off function).
