automatic transmissions
  • Thread starter Thread starter jrs87
  • Start date Start date Jul 27, 2005
J
jrs87
  • Jul 27, 2005
i've read that they are so much slower than the T5 cars. how is this so?
i also just read a couple threads down that T5s cant hold much power for very long stock.
wouldn't an automatic be an ok choice?
i really want to get a fox body but the only ones reasonably priced (around blue book) in my area are automatics
i also read that fox bodies don't need to be tuned a lot with certain mods. can shift points be programmed with an auto tranny?
thanks
TheBocSez
652
Converse, TX
Jul 27, 2005
  • Jul 27, 2005
AOD's are typically slower because you have one less forward gear (1-2-3-OD with an AOD as opposed to 1-2-3-4-OD with a 5spd).
Also, AOD are heavier than a T5 and take more power to drive.
AOD's are more consistant than 5spds as they shift faster typically but AOD's are notoriously weak transmissions stock.
OD band is weak and tends to break 1st. Being a lock up converter type transmission, at full throttle when the tranny goes from unlocked in 2nd to lock up in 3rd and OD, the stress of the converter being directly coupled to the crankshaft can cause 3/4 input shaft failure.
An AOD is not a bad choice. A good aux transmission cooler, a hardened input shaft, a high stall converter, and a good shift kit or valvebody and it will make a great difference.
On an AOD, shift points are controlled by the valvebody. On a AODE, they can be adjusted by a programmer.
Hope it helps some.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 27, 2005
  • Jul 27, 2005
The reason the autos in these cars dont usually run as fast as sticks are mainly, gear ratios, weight, drivetrain loss, lack of controling shift points, lack of controling launch RPM, etc...
T5s are lighter, have less drivetrain loss, have better gear ratios, and allow more driver control. A well built auto will run with a stick, but the money spent and streetability lost isnt appealing to most weekend guys!
As far as racers go, those in slower classes use standards for the same reasons, and a pro shifted stick car is easy anough to make up for the speed an auto can shift at!
In the end its all preference, but most will probably say go stick!
BrutalStang
261
PA
Jul 27, 2005
  • Jul 27, 2005
you lose a good percentage of power to the wheels when going through an auto, from all the reasons the guys above listed. it all combines to less power to the wheels.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
