Autometer A/F Gauge Install.. HELP!
  • Thread starter Thread starter crunchie12268
  • Start date Start date Aug 11, 2004
C
crunchie12268
599
Manhattan, KS
Aug 11, 2004
  • Aug 11, 2004
I just got an autometer A/F gauge for my 93 LX 5.0, I was looking at the wiring diagram and it says to hook up the violet wire to one of the three wires going to my O2 Sensor... which one? I have a black and two whites, what should I do? I called autometer and was on hold for 15 minutes before getting impatient....
9
9 Deuce GT
550
Geneva, NY
Aug 11, 2004
  • Aug 11, 2004
How much was it, and where did you get it from? I want the same thing.
Z
Zombietime
86
  • Aug 11, 2004
I have one that i'm selling. It's an autometer ultra lite a/f ratio gauge. I don't need it and it's in mint condition. PM me if you are interested.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 11, 2004
  • Aug 11, 2004
Use 43 (Dark Blue/Lt Geen wire) or pin 29 (Dark Green/Pink wire ) on the computer. Use Wire tap-ins from Radio shack P/N 64-3052. The computer is located under the passenger side kick panel. That keeps you from having to crawl under the car and make a weather proof splice in the wiring. You can use either one, or run a SPDT switch and use both. Then you can use the switch to select which side to view.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/t...91eecPinout.gif
The A/F gauges that use the O2 sensor signal will jump all over the place. The reason is that the O2 sensors "switch" between .2 volt lean and .6 volt rich with a curve that looks like the drop off a high cliff. The curve is almost straight up and down, so the voltage shoots from .2 to .6 and back down . again 2 or more times a second at cruse. You won't get much useful information except when the mixture is extremely lean or extremely rich, there is no middle ground.
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
