Autometer gauges in 86?
zeusmoto said:
broska im totally with you the stock 86 ones look like ***** and arent very accurate whatsoever. well i would be glad to introduce you to the best site to make the conversion
http://www.flemworld.com/
then go to rustang and 85 how to's
Thanks for the compliment on my gauge swap hot to Zeusmoto.
If anyone has any questions on the guage swap feel free to email me. I also have a few extra clusters lying around if you don't want to hack up your original one.
Mike (AKA - Rustang or Slugstang)
[email protected]
i think that the companies Flordia5.0 has a replacement set. They are great people to deal with if you call them---very friendly. They will sell you want you need, not stuff to make extra $ off ya.
Mechanical means it use no electric. Such as for oil pressure, you have a line that gets filled with oil to the gauge. A boost gauge has a vacuum line connected to it. water temp you have to run the line from the gauge to somewhere on the intake in the coolant flow...
Electrical gauges have senders that the gauges to connect to, making them easier to install. Accuracy should be about the same, so it's just what you prefer. On some styles, such as the phantoms, only full sweep needles are available only on mechanical gauges which is the reason I went mechanical. I think they are cheaper too.
