Autometer mini-shift light mounting positions?
Mustang5L5
Mod Dude
Feb 18, 2001
43,376
18,123
224
Massachusetts
I scored an Autometer mini-shift light, RPM activation module and 5000-5800RPM pill kit for dirt cheap all brand new (Part #'s 5330, 5310, 5355)
I was going to mount them in the usual spot on the steering column between the two main gauges but was wondering where some other good spots would be.
Any pics?
I dont have any pics of it, but i saw one in a fox at a car show.. he mounted the mini lite inside his ac vent (the one in the center) he said he took off the pedestal that it mounts with, took the a/c vents out, and just used some 3M 2 sided tape to hold it in place, then popped the vents back on. personally, i would use something different to mount it in there so the damn thing wouldnt go down your a/c duct, but he said he had it like that for a year with no problems..
Sounds good, but i think i am going to go with two gauges in the A/C vent so i can't do that.
Most likely i'll go with it on the column, but just trying to find some original ideas to do
I was going to put mine in the ac vent, but I decided to hide it in the dash between the speedo and tach behind the cover where one of the dummy lights go, in the spot of one that is not being used of course. Just drill out the back plastic where you want it and make your own bracket shape and screw it to the plastic, and you are done. Nobody knows you have it, even though a shift light is no big deal that needs hidden.
