Does anyone here have a rear axle Girdle, if so what brand? Did you have any clearance problems? Thank You!
I am actually looking at purchasing one while I have my rear apart and was reading an ad for Kenne Bell and their cover claimed not to have problems hitting the floor or the swaybar or the need to use the sledge on the floor above the rear axle. I started to question wether or not to get one.HISSIN50 said:Adam runs one - he will likely be in soon.
What kind of issues do you have? actual fitment or issues with the cap supports?
Stang8URMPRT said:The aftermarket rear covers are worth their weight in gold just for the drain and fill plugs installed in them.
89MustangGX said:I have heard of some problems with the floor, but it's basically a "self-clearancing" issue -- it's fixes itself after once or twice.
I have not seen someone actually write it out like that. 89MustangGX said:I have had a T/A (FMS) cover and now have a Strange (LBW?) cover. Both were very similar, I like both.
I have never had a problem with hitting the swaybar or the floor. I have heard of some problems with the floor, but it's basically a "self-clearancing" issue -- it's fixes itself after once or twice. This is actually the first I've heard of swaybar issues, mine have had quite a bit of clearance.
jerryD said:i think he means LPW.
I ordered mine directly from TA performancetunedin302 said:Not to hijack ... but where is the best place to get a T/A cover?
