  • SN95 4.6L Mustang Tech
axle studs?
  • Thread starter Thread starter Owned
  • Start date Start date Oct 17, 2005
O
Owned
104
  • Oct 17, 2005
snapped a axle stud on the passenger side front wheel, i already removed the other one and punched it out, can i punch the new one back in or is there a method to this? i went to autozone and they gave me the wrong size, the new one just sits all the way in and has lots of play, so im guessing its the wrong size, so now i gotta wait till tomorrow
mustang_montana
137
Oct 17, 2005
  • Oct 17, 2005
i had a shop replace mine on because they put the wheel on wrong in the first place. they had to go a size larger than the stock studs, and they used the impact wrench with an adaptor.
bobbyo
  • Oct 20, 2005
I'd get the studs from a Ford dealer. There something like $2 each...not bad for a dealer part. While you're there, pick-up a new lug nut also. After cleaning the stud hole good, feed the stud thru the hole in the axle and put an old wheel nut on the new stud and tighten it up so as to draw the new stud into the fit. You may have to put a properly sized socket over the stud as a spacer when you tighen-up. You will be wrenching hard to draw it in all the way. Once done, throw the old nut away and replace it with the new one you bought. Good luck!
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
