B CAM
You will lose hp and driveability with an aftermarket cam on a stock set up. Invest in a better top end first. An explorer top end can be had for cheap and will give you great results.
:nono:
On an otherwise stock (or near stock engine), a 15-20rwhp gain from installing a Cobra intake is a pipe dream. A 6-8rwhp gain is more likely.
yup.
On the other hand a good mass air meter is worth it, takes minutes to install and you get a proven .2 in the quarter.
No you probably can't feel it, but it's there.
So I've decided to just do heads, cam and intake all at once. I bought a used Cobra intake today and am now looking for a set of aluminum heads. I suppose I'll need to ugrade my injectors, mass air and throttle body..etc. Any suggestions on the right brand or combination or any other misc stuff I'll need?
U should do a quick search for H/C/I combinations on here and check out some of the mustang mags websites. They have done plenty of tests with dyno results of different combinations. Beware: For every person you ask you will get a different opinion.
