  • 2005 - 2009 Specific Tech
Back Pressure ?
  • Thread starter Thread starter tonyjrd
  • Start date Start date Nov 12, 2007
tonyjrd
  • Nov 12, 2007
I've been hearing a lot about fords needing a certain amount of back pressure and that free flowing exhaust isn't good for them. On my 06 gt I have high flow cats, x pipe, and slp loudmouths. Anyone else know anything about this and if I should buy different mufflers?
walter
1,054
Houston TX
Nov 13, 2007
  • Nov 13, 2007
well any car (unless turbocharged) requires a certain amount of backpressure to build some torque down low. if you increase the size of your piping and remove all restrictions you will see an horsepower increase (up to a certain extent) and torque diminishing. An exhaust system can really help you shape a power/torque curve.
LV51FER
318
Caerphilly, Wales, UK
Nov 13, 2007
  • Nov 13, 2007
http://www.uucmotorwerks.com/html_product/sue462/backpressuretorquemyth.htm
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Nov 13, 2007
  • Nov 13, 2007
If you still have high-flow cats, you have nothing to worry about.
T
TGJ
1,049
  • Nov 13, 2007
Backpressure is bad regardless of application. When you put a too efficient exhaust on a car, you are moving the torque curve upwards which equates to a loss of low end torque. It is not really lost, it is moved upwards. You have to watch what you do to your exhaust mods that you don't shift it upwards unless you intend to. That said, with the exhaust mods from the original poster, you are fine...
G
Gene K
18
  • Nov 14, 2007
In practical terms you are kind of correct,
Technically thats incorrect. With a correctly designed cam and exhaust (for the proper velocity curve) you dont really want back pressure. In fact you want negative pressure.
However what most people mean by backpressure is I want exhaust that is as restrictive at high rpm as I can get away with to make sure velocity doesnt collapse at low rpm resulting in flow reversion. The backpressure only occurs at higher rpm where it hurts power.
The ideal low rpm exhaust (assuming suitable cam timing) would be be
open headers with the correct primary and collector dimesion for that rpm.
tonyjrd
  • Nov 14, 2007
Thanks
Thanks for all the help
L
Is catback worth it over axle backs?
  • Lorencarson
  • May 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 15, 2025
89ripper
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
