back to the trans again
  • Thread starter Thread starter whtnotch
  • Start date Start date Sep 6, 2007
W
whtnotch
123
Chicago
Sep 6, 2007
  • Sep 6, 2007
As I posted before I'v had issues with the trans (TKO 600) it turned out to be the flywheel was balanced wrong so I then corrected the problem with the a 50oz ford racing piece it seamed fine,but now heres the complication I go to take off in first I have some "?trans/clutch/throw out bearing?" related problem where the car hesitates and shakes on a dead take off and forget about reversing into garage(you hear grinding and all kinds of ***** comming from underneath when in reverse).I can hear the throw out bearing I let off clutch and can hear it wineing/hissing and once i push in it goes away. Can this be the problem?(throw out bearing)?or is the clutch not adjusted properly?Would like to know a.s.a.p. so I can know if i should move on to the 1st and reverse on trans failing so I still have warantee on it. Anyone please help me out i'm kinda screwed trans been in and out a few times now and i'm willing to do it once more.(Ha like i got choice)All problems happen durring clutch ingagement.I'm almost sure its in the bellhousing.
It's a spec stage 1 clutch if it helps to know.I will provide you with any other info you need to solve this mystery.If your in Chicago and you know what your talking about ill buy you a couple 24 cases.I will not go to the perf shop on this.
thank you all alot. your time and is greatly appreciated
Kevin
W
whtnotch
123
Chicago
Sep 6, 2007
  • Sep 6, 2007
where you crazy guys and them select few gals out there that can help that know everything and anything about my problem
W
whtnotch
123
Chicago
Sep 6, 2007
  • Sep 6, 2007
bump bump.sorry bought being impatient,just wana get car goin.Outa cars for work....i'm down to driving the Chevy...
W
whtnotch
123
Chicago
Sep 7, 2007
  • Sep 7, 2007
bump.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 7, 2007
  • Sep 7, 2007
Kevin
clutch and tranny noises are kinda hard to diagnose without just tearing the whole thing down .....
W
whtnotch
123
Chicago
Sep 7, 2007
  • Sep 7, 2007
Just tore it down again...replaced the throw out bearing and threw it back in.Is the throw out bearing suppose to be making noise wit the clutch ingauged(in neutral)I know thats the sign of bad throw out bearing,but I just replaced a new one with another new one and it still making noise?.Car still making "grinding/chattering" on take off in 1st gear and horrably in reverse(sound like car wana fall apart in reverse) I dono what to do I wana run this car into wall
Somone please help.Anyone have this problem?I'm willing to break it down again if it will make it work mabey i'm just gana change the clutch I heard nothing but bad about SPEC Clutches,but my brother never had an issue in his Notch.Is the trow out bearing always suppose to be spinning?I can see it thru the Fork hole in bellhousing and its always spinning.i can provide any information needed i just need more opinions
bertman
55
Portsmouth Va
Sep 8, 2007
  • Sep 8, 2007
Do you have the throw out bearing on the fork the right way. If you dontit will make that noise. The vibration your feeling is probably because of the throw out bearing or fork. Do you have the bearing behind the metal tabs on the fork. If not do it. Aslo inspect the pivot ball for the fork and the fork itself. That pivot ball will wear flat spots on it. Let me know if this helps. Good luck. I deal with trannys for a living.Doing it for 12 years
W
whtnotch
123
Chicago
Sep 8, 2007
  • Sep 8, 2007
problem still remains...fork/bearing R A O.K. I broke it down 6 timez already seams to be getting better i got 85 miles on it so far,but still have that issue.If i'm rolling its much less violent of a take off almost nothing at all ,but off a dead start and im not focusing all on the clutch theres a problem.I drove car with my head under car and i can hear slight grinding on take off all other gears are fine tho its just on take off...Is it breaking in? Is it just breaking in or somthing its a steel flywheel so is it just longer to make its "groves" in the mating surface?Do you think its the pressure plate?like said before I ran the car around the block with a 28.5oz flywheel and i needed a 50oz could that of damaged it?
Kevin
P.S Help
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
