Just thought I'd post this for all the folks that have done an HCI swap recently (or doing soon).
Ever since I did my build up this summer (see sig), I have had a pretty rough idle, bucking from 1,000 to 2,000, and the idle/surge/die. I tried playing around with timing and the IAC, TPS, etc. etc. That helped a little. But on the timing, I started at 10 degrees advance, and went up. I went that direction mostly because AFM suggested my B-31 cam would probably perform best at 14 to 16 degrees.
Well I finally got curious enough to see what dialing the timing back down a bit might do. I started by dropping back down to 8 degrees. Wow. The idle was much improved, and the engine ran smoother and sounded tons better. Plus the bucking was toned down. Then I dropped down to 6 degrees. This seems to be my sweet spot. Now there is NO bucking, and the engine sound musical. Mmmmm long tube headers .....
Anyway, I was curious to see what that might do to the power I'm getting out of it. Seat of the pants feel is not quite so brutal, but that might be just because the engine is running so much more smoothly. So I fired up the Gtech. Before this last round of tweeking, the best 0 to 60 I ran was 5.6 seconds. On my first try now, I banged out a 5.1 with a crappy launch. LOL. I can't remember what my other stats were, but I think they all showed similar improvements.
Needless to say, I am quite happy with the way its running now (just need to reset my lower intake - another story). So keep that in mind for anyone working on tuning. It never hurts (I guess) to try moving in the opposite direction (a bit) from where you think you should be going.
Peace
