backfire
  • Thread starter Thread starter spade33
  • Start date Start date Jun 22, 2007
spade33
198
Tempe, Arizona
Jun 22, 2007
  • Jun 22, 2007
ok so now that i have figured out my spark problem i have a difrent one....when the engine finally tunrned over it backfired....and when i have it trying to turn over i can hear air coming out of the carb...so what can i do to fix this, could it just be my timming or what could be the solution
rbohm
6,698
550
204
tucson,az
Jun 22, 2007
  • Jun 22, 2007
1: remove the distributor cap and turn the engine in one direction until the rotor starts to move. it doesnt matter which direction. then turn the engine in the opposite direction again until the rotor starts to move. if the timing chain is in good condition then the rotor should move with little movement of the crank. if you have a substantial crank movement, more than a few degrees, then replace the timing chain.
2: bring the engine to tdc on the #1 cylinder on it compression stroke, and check the rotor position and firing order.
3: check your timing.
once you have completed these tasks, then run a compression check. i am betting that you will find a low cylinder or two, and with the fact that you hear air coming from the carb, you likely have burnt a valve.
spade33
198
Tempe, Arizona
Jun 23, 2007
  • Jun 23, 2007
thank you very much i will try that in the morning for sure, i probablly dont say this enough but you guys here are great your always helpfull and have quick very detailed answers to questions, honestly i don tknow what i would do without all of you if i had not foudn this sight, well to shorten that up thanks alot everyone who always helps out. and i will give all that a try tomarrow.
spade33
198
Tempe, Arizona
Jun 23, 2007
  • Jun 23, 2007
ITS ALIVE AND RUNNING AMAZING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
rbohm
6,698
550
204
tucson,az
Jun 23, 2007
  • Jun 23, 2007
excellent, what was the problem? rather what cured the problem?
spade33
198
Tempe, Arizona
Jun 24, 2007
  • Jun 24, 2007
yea i had the distributor in 180 degrees the wrong way haha yet again another stupid mistake
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
