  • 1994 - 1995 Specific Tech
backfiring after o/r x install
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Jun 20, 2005
1994Vib.RedGT
585
Denver, CO
Jun 20, 2005
  • Jun 20, 2005
I just recently installed my bassani o/r x and ever since I have, when I downshift, or rev in neutral up past about 2500~3000 RPM I get backfiring. Especially if I downshift and the revs go up to about 3000 it sounds like a gun going off, why is this??? Does it have something to do with the lack of cats?
P
pat farina
11
British Columbia
Jun 20, 2005
  • Jun 20, 2005
mine did that too check your timing you might have too much..
1994Vib.RedGT
585
Denver, CO
Jun 20, 2005
  • Jun 20, 2005
no, i just put new timing chain, water pump, plugs, rotor, and dist. cap last week, timing is not the issue.
CManT1914
3,172
Killeen, Texas
Jun 20, 2005
  • Jun 20, 2005
Is it actual backfiring or is it just popping? It's normal to have popping after installing an o/r mid-pipe, since it has no cats, it's just the unburnt fuel igniting in the pipes.
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Jun 20, 2005
  • Jun 20, 2005
exactly, i get ALOT of popping on decel.... and i love it, it sounds badass!!
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 20, 2005
  • Jun 20, 2005
yeah, backfiring sounds like a LOUD gunshot, not popping. it's Probably normal.
Scott
cobra dave
308
  • Jun 20, 2005
If your sig is still up to date it's probably because of the flows matched to the Bassani o/r x. I'm assuming your getting a hell of a drone too?
go-stang5.0
2,244
Glenview,Il
Jun 21, 2005
  • Jun 21, 2005
Have someone stand behind your car when you do this and see if there are fire balls coming out of your tail pipes. Its probably just excess fuel.
slidewayz94
18
Sacramento, CA
Jun 21, 2005
  • Jun 21, 2005
that popping sound is the best from an x or h pipe!!!
SaltWaterFish
208
Cedar Rapids, IA
Jun 21, 2005
#10
  • Jun 21, 2005
  • #10
Check for leaks. I've been told that cool air sucked threw holes in the pipes can cause popping during decel.
HGFireHazard
460
Michigan
Jun 21, 2005
#11
  • Jun 21, 2005
  • #11
When I had my LT headers put on and got the car back to take it to have the rest of the exhaust put on, I had 'gunshots' every 3 or 4 seconds, people would look at me like I was crazy. Turns out my mechaninc reversed two of the plug wires Anyways, we just turned them around and all was fine and I got my power back. It's amazing because that was the first thing that should have crossed my mind, but it never did until he mentioned it...
droptopford 5 0
427
Jun 21, 2005
#12
  • Jun 21, 2005
  • #12
backfiring IS unburnt fuel igniting in the pipes isnt it? the light popping on decel is not necessarily igniting fuel since my MAC cat back system used to do it lightly with the stock h pipe, now with the o/r h pipe i get this much louder than before, but actual backfire is much louder and should not occur very often unless heavy throttle shifting, or downshifting
1994Vib.RedGT
585
Denver, CO
Jun 21, 2005
#13
  • Jun 21, 2005
  • #13
no its not the popping, that is awesome, i have had the actual gunshot sounding noise, and it sucks
1994Vib.RedGT
585
Denver, CO
Jun 21, 2005
#14
  • Jun 21, 2005
  • #14
bump
HGFireHazard
460
Michigan
Jun 21, 2005
#15
  • Jun 21, 2005
  • #15
Alright two things. Cats (or a lack thereof) shouldn't have any effect on an exhaust except for maybe a few more horsies . Second, I know you said you just did your timing and all of that wonderful stuff last week, but find a light and check the timing anyways. Unless your O2s aren't hooked up right it's the only thing I can come up with.
1994Vib.RedGT
585
Denver, CO
Jun 23, 2005
#16
  • Jun 23, 2005
  • #16
timing is exactly at 10 degress, o2 senors are 4 months old, and hooked up properly. what next?
Black95GTS
1,644
Marlborough, MA
Jun 23, 2005
#17
  • Jun 23, 2005
  • #17
I get the popping same as you do. My timing is also dead on. I don't think its anything to worry about.
haulbalz
448
#18
  • Jun 23, 2005
  • #18
Ttt
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Monday at 4:57 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 3:09 PM
2000xp8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
