My backup lights are not working. Everything else electrically works on my 66. I replaced every wiring harness on the car with the exception of the neutral safety switch, which also includes the backup light switch. The starter will crank in park, so I know that the neutral safety switch portion is working properly.
However, when I hook up a continuity tester (ohm meter) between the wire going to the switch and the wire returning from the switch and put the car in reverse, I don't have continuity. Since I don't have continuity, is it safe to assume that the switch is the problem?
Thank You,
Carl
Thank You,
Carl
