bad alternator?
  • Thread starter Thread starter Tranceformer
  • Start date Start date Nov 19, 2004
T
Tranceformer
20
  • Nov 19, 2004
My stang has 156k miles and has an amp and subwoofer box. I noticed the other night when i put it in neutral to coast to a stop that the battery light comes on. But when i start moving or start revving the engine up the light goes away. Is my alternator going bad?
PhLoBuS
473
Beverly, MA
Nov 19, 2004
  • Nov 19, 2004
If you have a stock alternator its simply to weak... when I added my U/D pulleys I noticed the car struggling to idle etc... get a 130 amp alternator
86StangLX
52
  • Nov 19, 2004
Exactly what he said.
HISSIN50
34
129
Nov 19, 2004
  • Nov 19, 2004
did this just start? did you have the sub before? many parts stores will check the charging system out for ya for free. battery should show ~12.6 volts when the car is off. should be around 14.5 volts at 2K rpm.
do the symptoms change if you dont have the stereo on?
good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 20, 2004
  • Nov 20, 2004
Here's websites with pictures of the 3G installation...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
Use theses sites for information on the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires will be overloaded to the point of catching fire and burning up the wiring harness.
Electric fan = 3G alternator if you want long life & reliability from your car.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
T
Tranceformer
20
  • Nov 20, 2004
I found link...
http://www.fordmuscle.com/archives/2001/03/paperformance/index2.shtml
step 14 & 18, it looks like they connected the two 10gauge wires you said not to connect?
87mustang347
82
  • Nov 20, 2004
or it could juss be that ur connections are abd at the battery or u need new terminals
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
