bad fuel pump question
noslow1986
274
oswego Il
would a bad fuel pump cause a back fire and miss at high rpms and cause a hard start. took it to a shop and they said my fuel pump is going out. just wanted to know if these systems would cause a fuel problem. dont feel like getting dick around cause i dont have alot a lot of money to spend and find this is not my problem
soon as i hit 4000 rpms is when it happens starts poping back firing when i come to a stop sometimes it will die. i did have a bag egr valve but they just used a plate and block it off. im thinking my pump is slowly going to die
when mine went out, took 3-4 starts for it run... then ran ok... pretty much when it fails its going to fail! soon it wouldnt start at all... i never noticed miss etc... under WOT... so i dont know
its a 91 motor convert to mass air. i converted it a long time ago and now i have this problem were it seems im not getting enough fuel, fuel filter still should be good i just change it. but im still getting really hard starts and high rpm miss. the guy at the shop said that my fuel pump is bad. if i get a tester and check fuel pressure what should my pressure be at i never did this before
I've had pumps slowly crap out. It feels like hitting a rev limiter at higher RPM, or when the pump heats up (diaphram gets weak) and it craps out till it cools off.
Check your pressure during this time if you safely can. Pull codes and note any Lean condition codes.
Good luck.
To not toss more money than needed at it, getting some diagnostics in when it's acting up is key. You noted hitting a wall at 4K RPM - that can also be a TFI or coil on the outs as well.
I just mentioned it so all things are considered.
Good luck.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
I had a camaro that did the exact same thing, misfired, sputtered, but would idle and crank fine, but when it got hot it would die. It ended up being the fuel pump. Make sure you check your fuel pressure and if it isnt in the proper range 38-39 or so PSI then thats probably what it is.
