Bad fuel pump symptons...
  • Thread starter Thread starter Boss 351
  • Start date Start date Aug 22, 2006
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Aug 22, 2006
  • Aug 22, 2006
Well I have a problem at WOT, and that is my engine is running out of fuel. Fuel filter is new and injectors are clean. I undid and checked my EFI harness before so that's in tip top shape as well. It's basically stuttering above 3500rpm but I don't hear any pinging.
One thing I noticed is that when I turn my electric fan on, my fuel pump makes a different sound. I still have the stock alternator on there so maybe my pump isn't getting enough voltage? I'm thinking about getting a better pump anyway, something like a 190 or a 155?
superhuaman
907
Harrisburg, PA
Aug 22, 2006
  • Aug 22, 2006
what kind of combo do you have?
you should have a 3g alternator (or any kind really if its bigger than stock) for your electric fan. that way you dont have to worry about voltage starvation of your fuel pump.
if you upgrade your fuel pump, just get a 255, theyre cheap on ebay, like $60
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Aug 22, 2006
  • Aug 22, 2006
Currently it's stock but not for long. I have performer RPM intake, 65mm TB, 73mm MAF, 24lb injectors and aluminum heads coming in for my new engine which will be just a 306 for now. I was going with a stroker but changed my mind at the very last second...
superhuaman
907
Harrisburg, PA
Aug 22, 2006
  • Aug 22, 2006
oh ok...usually a stock pump will only be a problem when you upgrade other things, but if it's bad enough (like yours probably is) then it will cause that "rev-limiter" feeling. it would not hurt to change the pump. just drive until the tank is empty, and then drop it. i did mine in a couple hours.
EDIT
also, the fuel filter can cause this problem, but you said its fine.
is the problem present all the time, or just when the electric fan is on?
it wouldnt hurt to pull codes either...
HISSIN50
34
129
Aug 22, 2006
  • Aug 22, 2006
You've noted that pressure is less than adequate at WOT at 3500 RPM (or whereever your issue happens)?
The lack of pinging is a little strange.
I agree that with your plans, you'll need a pump anyhow - you can swap it early if desiring to do so.
Good luck.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
