bad ground? where to look?
i relocated the battery to the trunk, i converted to a 5 speed. when i sit in the car and try to turn it over i can here it turning over but not as good as it should.. so i had my buddy lean in through the window and turn the key, as he leans through he is obviously touching the window frame of the door, and he got shocked pretty good. What am i missing? i got the engine grounded to the frame... the battery is grounded to the rear seat frame... Let's first start off by saying im new to this electrical/ building a car up thing. Any ideas guys would be greatly appreciated.... maybe i havent given enough info?
Thanks
Derek
Reactions: utemachine
Rear mounted battery ground wiring. Follow this plan and you will have zero
ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot
on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the
rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean
shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to
the chassis ground where the battery was mounted up front. Use a 5/16” bolt
and bolt down the 4 gauge engine to chassis ground, make sure that it the metal
around the bolt is clean & shiny. This is the alternator power ground.
attachment.php
The computer has a dedicated power ground wire with a cylindrical quick connect
(about 2 ½”long by 1” diameter. It comes out of the wiring harness near the
ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground
in the same place as you bolted the alternator power ground. This is an
absolute don’t overlook it item for EFI cars
Note: The quick disconnect may have fallen victim to damage or removal by
a previous owner. However, it is still of utmost importance that the black/green
wires have a high quality ground..
Picture courtesy timewarped1972
Crimp or even better, solder the lugs on the all the wire. The local auto stereo
shop will have them if the auto parts store doesn't. Use some heat shrink tubing
to cover the lugs and make things look nice.
For a battery cut off switch, see Moroso : Category Display
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10 gauge wire they recommend is even less adequate that the stock Mustang wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/2" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug there is a green wire. It is the sense lead that turns the regulator on when the ignition switch is in the run position. Cut the green wire and solder the 40' of green wire between the two pieces. Use some heat shrink to cover the splices. See Ford Fuel Injection » How To Solder Like a Pro for some excellent help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire. Try to run the green wire inside the car and protect it from getting cut or chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs. Do not add the jumper between the 1/2" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies a turn on signal to the regulator when the ignition switch is in the Run position. Turn the Moroso switch to off, and the sense voltage goes away, the voltage regulator shuts off and the alternator quits making power.
The fuse & wiring in the following diagram are for a 3G alternator. The stock alternator uses a dark green fuse link wire that connects to 2 black/orange wires. Always leave them connected to the starter solenoid even if you have a 3G alternator.
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring
Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
"J" I have a question for you. In that picture where the screw driver is pointed at the ground. That one "O" connector that has the two smaller wires connected to ground. On my car one of the wires is cut. I know that one is for the computer but what is the other one for? I have just two ground connections at that spot (one for block and one for computer). Just dont know why the third wire is cut and what the other end went to since its not in the area so I can trace it back.
The picture shows the common ground point for the battery , computer, & extra 3G alternator ground wire as described above in paragraph 2. A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
The extra wire is you asked about is probably the pigtail from the battery ground cable. See the drawing below
Correct negative battery ground cable.
56567d1230679358-positive-negative-battery-cable-questions-86-93-mustang-oem-style-ground-cable.gif
The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to its proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness.
  • 56567d1230679358-positive-negative-battery-cable-questions-86-93-mustang-oem-style-ground-cable.gif
Okay so to be sure I under stand. Two wires to the chassis ground go to the battery negative post? One 10 gauge and one 4 gauge? On mine I only have two wires at the chassis ground that connect to anything. One 4 gauge to the neg on batter and one to the computer.
Hmm im going to check my grounds , thanks jrichker.. I have converted to a carb so i have no computer. I also have a true one wire alternator... This is how i have it laid out. ( plz tell me if there is a prob with this setup.) battery and solenoid located in trunk... Battery + to solenoid --- Battery -NEG to rear back seat seat buckle bracket. Then 1 gauge wire from rear solenoid to solenoid on the starter, with one gauge from starter to my 1 wire alternator... i guess i dont know how all this leads to getting shocked by the key when turning it and standing outside the car .... Hmmmmmmmm
Any ideas?
ground problems.
attachment.php
be good to go.
Moroso diagram.
How it works:
attachment.php
