Bad H-Pipe?
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Jun 11, 2004
Black Sun 5.0
1,337
L.I., N.Y.
Jun 11, 2004
  • Jun 11, 2004
I've had this ongoing overheating thing with my car. Stop and go or idle, everything is great. But hit the highway, and the temp climbs real well. Radiator, water pump, t-stat, etc. have all been ruled out. What about a bad h-pipe? I have one of those BBK pipes with cats. I know the cats are shot, I used to hear them rattling around down there and I no longer pass emissions. Any thoughts out there?
green
291
  • Jun 11, 2004
maybe the cats are plugged, alot of junk in them. that probally would do that. id take it out and beat the stuff out of them. just get a settl bar about 1 inch round and put the bar up there and beat all the stuff out.
10HoleLX
257
Southern California
Jun 11, 2004
  • Jun 11, 2004
One easy way to check for clogged cats is like this.
With engine at operating temp (or close to it) try to feel if there is a major temperature change before and after the cats.
If its super hot before the cats and cooler after, then you have clogged cats.
Worth a try
LT1Killa
192
  • Jun 11, 2004
Uh... won't you burn the crap outta your hands doin that?
88stangmangt
2,332
Stafford,VA
Jun 11, 2004
  • Jun 11, 2004
um noooooo.................................. common sense will tell you to use a heat gun to test it out craftsman sells nice one's.
5 Liter Mustang
119
  • Jun 11, 2004
you dont literally have to hold your hand to the H-pipe.. if you are an inch or so off, you should be able to feel the temp. difference, w/o burning your hand.
I have one of those craftsman laser thermometors though... it does come in handy.
R
ratrapp
510
buena vista,va
Jun 12, 2004
  • Jun 12, 2004
an easier way to tell is remove your two oxygen sensors and drive the car because this will give your exhaust gas a place to exit.it will be crappy sounding but it will tell you if thats the problem without gutting the converters.
dvs bullet
326
Ontario, Canada
Jun 12, 2004
  • Jun 12, 2004
sometimes when yours cat are rattling the material inside can wedge itself sideways in the cat chamber causing a block in the pipe like the others said check the exhaust temp before and after. You should also hear a wheezing sound when you hit the gas
Black Sun 5.0
1,337
L.I., N.Y.
Jun 12, 2004
  • Jun 12, 2004
Wheezing sound, eh? We may be onto something here.
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
