bad harmonic balancer?
  • Thread starter Thread starter carbed 85 gt
  • Start date Start date May 21, 2005
carbed 85 gt
121
Honolulu HI
May 21, 2005
  • May 21, 2005
So lateley last week I start to hear a little rattle coming from the front of the engine. I thought it might be an accesory so I pulled the serpetine belt and it got a bit quieter. So the idler pulley is a bit noisey but its still there with no belt. I listened from the valvecovers and the bottom of the motor near the tq converter and exhuast. But it seems to be coming right from the front on the balancer. It isnt visibly wobbling or anything, how can I tell. The sound increases speed on engine speed and does it in all gears and park and neutral. Any suggestions guys? Thanks
D
DouglasOhio
116
Canton Ohio
May 22, 2005
  • May 22, 2005
Hey, a few weeks ago i had a problem with my HB. It was wobbling and actually hitting the timing marker and this sounded like valvetrain noise. Not sure if this is your problem becuase u say its not wobbling. GOod luck.
D
darkarrow
31
  • May 22, 2005
i had this same problem 3 months ago, i heard this clack clack clack sound from the front of the engine. i had just done a $40 from standard to synthetic oil change, and i had thought my engine was know screwed, but it turned out the 4 bolts holding the pulley onto the harmonic balancer had come loose or had broken. i got under the car tightened them and the noise disappeared. it was making the clack sound, like from valve train problems, so check the pulley extensively, hopefully it is a case of a few loose bolt you can tighten. good luck.
carbed 85 gt
121
Honolulu HI
May 23, 2005
  • May 23, 2005
Well I checked the bolts and they seem fine, but looking at it I found the rubber between the inner and outer rings was working its way out towards the timing chain cover. Its out about 1/4 to 1/2 inch all the way around the back of it. I tried to wiggle the outter section and it moves a tiny bit but not freely. So I probably need a new balancer right. So what is affordable out there, seen some for 3-4 hundred dollar SFI approved stuff. Dont think I nned this type on a stock 5.0
Bobert
63
  • May 23, 2005
I had one that had the rubber pulling out like that and I replaced it with just another stocker. Seems fine (and cheap) since they seem to last an easy 100,000 miles on cars I've seen.
carbed 85 gt
121
Honolulu HI
May 23, 2005
  • May 23, 2005
Cool, I had never seen one do that. I always thought they cracked and the outer ring slipped. Thanks
Bobert
63
  • May 24, 2005
Now that I think about it again, I think mine was pulling out towards the front, not the back. Guess it doesn't matter, sounds like you need a new one anyway.
Now it seems there was one precuasion everyone told me to make while taking it off (I think to keep from buggering up the crank threads), but I can't remeber exatly what it was now. Several years since I did it and I think alzheimer’s is already setting in :o
R
ratrapp
510
buena vista,va
May 24, 2005
  • May 24, 2005
i got my balancer from lrs for $180.it's the sfi approved one and comes with the spacer.
D
DouglasOhio
116
Canton Ohio
May 24, 2005
  • May 24, 2005
I got mine from autozone for $65, its fine.
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
