Bad idle after headlight install (WTF)
  • Thread starter Thread starter DirtyD916
  • Start date Start date Nov 17, 2004
DirtyD916
804
Norcal 916
Nov 17, 2004
  • Nov 17, 2004
well during the headlight swap process i removed the stock airbox for more room. But once i got it back on and took her out of the garage she idled really poorly. It jumped all over from 700-1150rpm and back. I took it aroudnt eh block adn it seemed to idle fine. I then turned the car off and then back on to find the ****ty idle was back again. So wats the deal?
HISSIN50
34
129
Nov 17, 2004
  • Nov 17, 2004
is it possible that you disturbed the MAF?
good luck.
DirtyD916
804
Norcal 916
Nov 17, 2004
  • Nov 17, 2004
no i didnt touch it but now that you mention i will take the air box backl off and check to make sure.
five_o_stang
92
Georgia
Nov 18, 2004
  • Nov 18, 2004
When you removed the airbox did you mess/adust with or remove your air-flow sensor? did anything get into your meter that could be blocking the sampling tube a small piece of dirt or paper could cause a bad reading?...that's the only electrical component near the airbox so I'd start there and make sure everything there is sound..
also, are your battery connections good?...did you disconnect the battery to do the lights or knock the negative cable loose while foolin' around the driverside headlamp?.....
I'd start here and see what's up. Go back through EVERY step you made and make sure everything checks out....that usually finds and fixes the problems...otherwise I'd wonder if the problem is unrelated to the headlamp/airbox work.
DirtyD916
804
Norcal 916
Nov 18, 2004
  • Nov 18, 2004
no all the cables are find. I figure its not that big of a problem and i will just sleep on it until the next time i have to drive it. then i'll be pissed again
N
Notched
113
  • Nov 18, 2004
well what kinda headlights? if aftermarket, it could be putting excess drain on the battery. and after reading the electrical prob with the lightsw, i would think its most likely the alt. i have one like i posted in that thread, but if you want to "solve" the prob- if it is the alt, but a alt that produces more amps then the stock, like a 150 or 170 (not sur what stock is_)
if its not that, then its either the batt or like they said. the maf
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
P
High idle issue and leaking after running.
  • PHoffman
  • Dec 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
General karthief
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
