  • 1994 - 1995 Specific Tech
bad idle and stalling...please help
  • Thread starter Thread starter SVT3183
  • Start date Start date May 28, 2006
SVT3183
180
S Jersey
May 28, 2006
  • May 28, 2006
i'm having a bad luck weekend with my car.....with this particular problem my idle is terrible. it won't stay at one rpm, just keeps dropping almost to the point of dying sometimes and then going back up only to drop again, almost bouncing. also, sometimes when i'm driving and coming to a stop when the rpms are at idle the car will stall when i push in the clutch. other than this the car is running strong throughout the rpm range. mods are in my sig and i don't think they have anything to do with the problem. the msd box is currently not connected and i checked the coil and it was fine. today i cleaned the mass air element and sprayed carb cleaner in the IAC and neither helped. does this sound familiar to anyone. bad tps, iac, egr? some type of sensor? my engine light is not on
HISSIN50
34
129
May 28, 2006
  • May 28, 2006
Pull the codes anyhow (non-critical codes can be stored even though the CEL is not on - your issue could qualify).
To properly clean the IAC, it has to be removed. Because it occurs static and while coming to a stop (both cases where the IAC is used), that points to the IAC still.
A vac leak can cause similar issues however.
Good luck.
KENS89LX
302
Cross lanes Wv
May 29, 2006
  • May 29, 2006
Try cleaning the throttle body, and the egr valve.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
3.8 start problems. New edge 2003
  • Mayk.i.
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
