I can tune the idle up to 11.5-12 AFR (AEM wideband kit). Leaning it further causes white smoke. At 11.5-12 it has a healthy sound and no visible smoke. I was able to get up to 13 with idle screw just about 1/2 turn remaining to be fully seated; when fully seated engine stops (so power valve works).
My setup: 302 with mild cam, 650 cfm double pumper, engine at operating temperature.
Is it normal for holleys to run at richer AFR? Have you been able to run near stoich AFR at idle (14.1-14.5) with similar setup and have clean emissions?
