  • SN95 4.6L Mustang Tech
Bad MIL Eliminators???
  • Thread starter Thread starter Saleen311
  • Start date Start date Nov 9, 2006
Saleen311
67
Hampton, Va
Nov 9, 2006
  • Nov 9, 2006
About a day after my O/R install my check engine light came on. Car doesnt act any different than it did from the end of install until the light came on. How common are defunct MILs?? I dont think it could be anything else. The exhaust is on tight and i put new gaskets on and everything.
BooWFO
991
Louisville, KY
Nov 9, 2006
  • Nov 9, 2006
best thing to do is have the code pulled and make sure it's the mils not working correctly...
As for how common, depends lots of people had issues with the plug and plays, although most of those were after driving for awhile.
R
Ram5773
66
Melbourne, Florida
Nov 9, 2006
  • Nov 9, 2006
I had two sets on my car, plug and play and the splice in ones, both didn't work. I was told to use spark plug anti fowlers to move the O2 sensor out of the exhaust stream and it worked great, no light anymore.
Buy the anti fowlers and it will solve your problems as long as that is your problem, Check your codes, I changed my mil eliminators from side to side to verify which mil was bad and then I checked to see if the codes were the bank 1, bank 2, downstream or upstream.
Take a read through this site http://forums.evolutionm.net/showth...37&page=1&pp=15
If you have any questions please ask, it works, it's on my car and my computer seems to be a sensative pain in butt.
Ram
four six
506
Hobart, IN
Nov 9, 2006
  • Nov 9, 2006
Check your front O2s. Also reset your battery. If it comes back on pull the codes. Auto Zone/Advance does it for free
sgarlic
3,085
Nov 10, 2006
  • Nov 10, 2006
Yeah definately get the code pulled. You could have a leak somewhere which may trigger the fronts to throw a code.
What kind of mil eliminators are you using? Some you have to break the little tab off or they won't plug in fully. Others, if you wire anything backwards, it'll throw a code. My guess is you have a loose wire.
C
Confirming approach for P0420
  • crazyone64
  • Oct 21, 2024
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2024
89ripper
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
squeak93
