Bad Mod
  • Thread starter Thread starter Blue Rocket
  • Start date Start date Nov 21, 2007
Blue Rocket
Cartersville, GA
Nov 21, 2007
  • Nov 21, 2007
I recently posted under 4.6tech and I've had no responce so I figured I;d ask fellow pushroders. I have a 2001 f150 with a 5.4liter it just started skipping. I've replaced the plugs a couple of weeks ago. Does any one know how to check the coils or which coils normally go bad. I don't really feel like spending the money on a set if I can get by with just replaceing 1. I pulled the wires off of the coils one at a time and I could not tell any difference . the truck is not throwing any codes.
P
PJC Racing
199
  • Nov 21, 2007
If its a misfire it should have a code (OBDII)
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Nov 21, 2007
  • Nov 21, 2007
This will likely get moved to the "Other Auto Tech" forum.
They sell a nifty little testing tool at places like Checker Auto and Autozone that plugs in-line between your plug wire/coil-on-plug boot and the spark plug, itself. It's basically a little light that just shows whether or not that plug is actually getting spark to it, without having to run the motor with the plug removed and laying on the block (the old-school method, more useful for no-start conditions than for drivability troubleshooting). Might look into one of those for around $15 to tell you whether or not you're getting spark to each of your plugs.
Usually on most OBD-II cars, you'll get a code thrown if there's any kind of a misfire, and it'll even tell you which cylinder is having problems (unless you just get a "multiple cylinder misfire" code). Even if the "Check Engine" light isn't on, there might still be some stored codes that you can pull. Did you actually check the codes, or is it just not tripping the "Check Engine" light?
Also, you can always start pulling the spark plugs you just put in and comparing their appearances. If you've got one with a whole lot of deposits on it, notably more than the others, that's likely your problem cylinder. What types of deposits it has on it can point to a whole variety of different problems.
N
n2o-89fox
116
ca
Nov 21, 2007
  • Nov 21, 2007
with my 99 lightning it never threw a code. Also the one that normally goes bad is the pass side back one. you can have ford test them for 90 bucks and then replace it yourself costing a total of 110 dollars. I have a little tool to check the coil that I bought for 70 bucks but my problem was that it never missed at idle only at wot. Also you can check the resistance on them to check them. If you check out svtperformance.com and go to 2nd gen lightnings they will help you out.
baldy1
124
Portsmouth Va
Nov 21, 2007
  • Nov 21, 2007
Are you sure your not hitting the rev limiter Since it only does it at WOT
rockytoohot
48
  • Nov 21, 2007
I would check with you local Ford dealer as there are new programming flashes very often. There may be one that will fix your problem.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Fuel 1990 mustang gt 5.0 no ground signal to fire injectors
  • brandyn200
  • Sep 5, 2025
Fox 5.0 Mustang Tech Sep 6, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
