A friend of mine replaced his aode trans that was bad on a '94 Stang this weekend and the tcc sensor harness had trans fluid in it, like the sensor leaked through. He also put a newer trans in his car, one that uses mercon V fluid, year unknown. I don't know but does he need to have the trans tuned since it is newer than the one he replaced? He says all the wiring harnesses hooked up properly execpt the trans range sensor, but he was able to use the old trans range off his old trans but his o/d light flashes on and off. He says he cleaned the fluid out of the sensor harness before re-attaching it to the new/used tcc on the replacement trans. Anyone know?
