Bad Vibration at 70+ MPH
  • Thread starter Thread starter onefstsnake
  • Start date Start date Mar 13, 2009
First Prev 2 of 2
MattSVTContour
41
Atlanta Area
Mar 27, 2009
#21
  • Mar 27, 2009
  • #21
onefstsnake said:
Well Ive searched and have found alot of great info but nothing to solve my vibration problem.
Car is a 93 Coupe. TKO 600 trans, FMS Aluminum DS, Auburn Pro Locker, 31 Spline axles, and FMS 4.10 gears.
Vibration happens at 70mph and continues at higher speed but doesnt get worse.
No vibration under 70mph. I can put the trans into neutral and the vibration is still there. The vibration is so bad I cant see out of the rear view mirror.
Ive tried 2 sets of wheels/tires, U Joints have no play, and the wear patern on the gears looks good.
I also have a gear whine under deceleration.
Could a bad bearing in the rear cause a vibration like this?
Also how much play should there be between the splines of the axle and the internal splines in the carrier?
Any help would be awesome!
Thanks,
Ken
I had too much backlash (.020) and moving it down to around .015 took away my gear whine on decel. You might want to check that.
While I was in there I checked the axles and one of mine was bent pretty bad, .070 in the center if I supported the ends and spun it. After that, most of my vibration is gone.
P
phutch11
328
Mar 27, 2009
#22
  • Mar 27, 2009
  • #22
+1 on backlash and +1 on driveshaft angle
Posted via Mobile Device
jhonda
125
Huntersville NC
Mar 27, 2009
#23
  • Mar 27, 2009
  • #23
More than likely its your rear tailshaft bushing on your transmission. Check to see if you can move the driveshaft up and down where it goes into the tranmission. Thats what mine is.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 27, 2009
#24
  • Mar 27, 2009
  • #24
Smart man. Simplist things first. That'd be my guess.
fford
1,020
Palmyra, PA
Mar 27, 2009
#25
  • Mar 27, 2009
  • #25
Had someone I knew and it was a bent shaft in the tranny. Everything shifted fine, sounded fine, but the tranny had a bent shaft.
wildstang90
87
Bristol, TN
Mar 27, 2009
#26
  • Mar 27, 2009
  • #26
You still have the dog bone looking thing on the rear end? When I took mine off it did the same thing so I just put it back on.
onefstsnake
792
Northern VA
Mar 27, 2009
#27
  • Mar 27, 2009
  • #27
Driveshaft is bent.
I put it on a lift and lifted the rear susp. up and let the tires roll a bit and you can see the DS wobble.
Hopefully I can get it straightened out....
MattSVTContour
41
Atlanta Area
Mar 28, 2009
#28
  • Mar 28, 2009
  • #28
Might be simple to check, but not so simple to replace!
KamiKaziDK
555
Mesa, Az
Mar 28, 2009
#29
  • Mar 28, 2009
  • #29
Straighten? Just hit up craigslist, there's enough people that buy aluminum driveshafts or wreck mustangs that you should be able to pick one up for 20 bucks......AND I just noticed you had a tko in there and am not sure if they require different driveshafts. HAHA. well.....glad you found the problem Double check all your seals to make sure the wobble didn't goof any up
onefstsnake
792
Northern VA
Mar 28, 2009
#30
  • Mar 28, 2009
  • #30
Yeah there is a local driveline shop that Im going to call and see if they can fix the DS.
Seals are good.
Im actually kinda glad its just the DS and not something in the rear end.
R
resistol
tulsa ok
Mar 28, 2009
#31
  • Mar 28, 2009
  • #31
I just got my 87 gt a couple of months ago and I had the same problem but at 80mph. Turns out my front u joint was locked up on one side which caused my yoke to wear on one side due to the bushing in the rear of the transmission. The u joint fixed most of it but the yoke fixed it all.
BStevens
127
Grand Rapids, MI
Mar 31, 2009
#32
  • Mar 31, 2009
  • #32
i've got the same issue basically...
I've tried a new tranny, new driveshaft, new wheels & tires... basically everything but a rear end, bearings & gears. i did have my brother in law whos a mechanic take a look at the gears and everything checked out ok.
kind of annoying...
T
thebullschmidt
65
#33
  • Apr 1, 2009
  • #33
im kinna leaning toward a bushing in the tranny my self. my car had a similar vibration at bout 85 but it was my pilot bearing... i figure its something similar except a little further back.
First Prev 2 of 2
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
mustang gt rear end/differential rebuild cost vs doing it myself
  • sharpright
  • Nov 4, 2020
15K
1996 - 2004 SN95 Mustang -General/Talk- Jun 22, 2021
Mustang5L5
SOLD 1991 LX hatch 5.0 (347/TKO) Elgin, Texas
  • LarsD
  • Sep 20, 2019
3K
Fox Body Mustangs For Sale (1979-93) Sep 20, 2019
LarsD
Driveline Shimmy
  • 88CougarMan
  • Dec 21, 2017
2K
1996 - 2004 SN95 Mustang -General/Talk- Feb 4, 2018
General karthief
