Bad vibration when turning
  • Thread starter Thread starter Dmarstroker
  • Start date Start date May 4, 2007
Dmarstroker
116
Vancouver, WA
May 4, 2007
  • May 4, 2007
No matter how fast or slow I turn there's a vibration that you can feel through the floor board, and it seems its coming from the alum. DS. Any ideas what to check? I know I should check the u-joints, input shaft, and trans mount. Does anyone think the pinion angle could be off?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 4, 2007
  • May 4, 2007
Your pinion angle shouldn't be off with bolt on Upper and lower control arms. It could be off if they are adjustable. Now the fact that you have the vibration when you turn makes me suspect the steering linkage hitting the driveside header. Mind you, you would feel that in your steering wheel. Check to see if when you turn if something is touching the engine or drive train somewhere.
Another question would be does it vibrate when you turn your steering wheel while the engine is running but you are stopped?
Dmarstroker
116
Vancouver, WA
May 4, 2007
  • May 4, 2007
No it doesnt vibrate when Im at a dead stop with the engine running. My U/L control arms are also adjustable. Do you have to have a special tool to measure the pinion angle?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 5, 2007
  • May 5, 2007
basically its just measuring an angle. I'm sure they make some magnetic based protractor for measuring the angle.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
