bad vibration
  • Thread starter Thread starter jake_1977_77
  • Start date Start date Nov 29, 2007
J
jake_1977_77
33
Columbus, Georgia
Nov 29, 2007
  • Nov 29, 2007
I have a 92 hatch, when I get up to 70 mph my shifter vibrates really bad til about 80 mph then it is fine again, what could be causing this vibration??? I have a tremmec 3550 5 spd, aluminum driveshaft, any info would be great, by the way the car is for sale!!!
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Nov 29, 2007
  • Nov 29, 2007
Does this happen when the car is in drive? Neutral? Or it doesn't matter?
Fred
J
jake_1977_77
33
Columbus, Georgia
Nov 29, 2007
  • Nov 29, 2007
I believe when I take it out of gear it quits, not exactly sure! what is it if it does quit, and what is it if it doesn't quit vibrating!!!?????
9
91foxbod50
486
  • Nov 29, 2007
dont let the guy who is buyin it go past 70
J
jake_1977_77
33
Columbus, Georgia
Nov 29, 2007
  • Nov 29, 2007
the dude I bought it off said it was because of the aluminum driveshaft, if I was to put the stock one back on then it would not vibrate like that, is that true?
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 29, 2007
  • Nov 29, 2007
doubt it unless the alum. shaft is bent or something usually its the other way around. my 79 had a bad vib. at speed and it was because the pinion angle was off due to bad uppers.
J
jake_1977_77
33
Columbus, Georgia
Nov 29, 2007
  • Nov 29, 2007
only at certain speeds or constant vibration? another guy said it is because I need me wheels and tires balanced, could that be a factor of this? I have 18" saleens on it, 5 lug conversion
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 29, 2007
  • Nov 29, 2007
constant
Blandnuts
1,172
124
124
FloorDuh
Nov 29, 2007
  • Nov 29, 2007
Try and find out when the vibration occurs (in/out gear). This helps with eliminating the transmission. If the vibration happens only when it's in gear, the transmission should be the bad guy. If it doesn't matter then it's something else besides the tranny.
To eliminate the tires, put the car up on four jackstands (or 2 in the rear, I just like to be safe with 4). Take off the rear tires and bring it up to speed and see if the vibration still occurs.
While it's up on jackstands look over the rear mounting points and make sure nothing is lose. You could also have someone watch the driveshaft while it's turning to see if anything looks out of place.
Fred
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 29, 2007
#10
  • Nov 29, 2007
  • #10
if you take off rear tires put lugnuts back on to hold drums on or all kind of bad stuff is gonna happen!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Blandnuts
1,172
124
124
FloorDuh
Nov 29, 2007
#11
  • Nov 29, 2007
  • #11
I should probably add a disclaimer huh?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Nov 29, 2007
#12
  • Nov 29, 2007
  • #12
Dude, your avatar is freaking me out...
Might also consider swapping the stock tranny mount with a poly mount (Energy Suspension gets my vote). When I swapped the mount out on my T-5 for a poly unit, the shifter no longer wiggled and flopped around all of the time like a rubber weenie.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
