I've got an engine vibration above 3000 rpm sitting still or freewheeling in neutral,it's an aod to t-5 swap had flywheel resurfaced,should be right flywheel28 oz, king cobra clutch set is new feels nasty as you increase rpms up into 5000 range balancer looks fine by the eyeball,also vibration at speed in driveline think it's a non- related issue not sure,starter drive sound like it's not releasing all the way , runs for about 3 seconds after car starts,, also installed shim thinking that it was touching,NO GOOD this is starter #2, maybe solenoid on fender? Donor car was 86 mustang, put into 93 stang stock with 410 gears please help !!!!!!
