balancer broke while driving
  • Thread starter Thread starter yelbigbirdlow
  • Start date Start date Apr 30, 2004
Y
yelbigbirdlow
71
DFW Texas
Apr 30, 2004
  • Apr 30, 2004
What kind of B.S. is this, here i am driving between 35 and 40 mph when my entire car starts to vilently shake. I pull over and look under my hood and see that my belt is all chewed up and that my crank pullie and balancer are half way off the crank . i pulled the balancer off (more like it fell off)and find that a third of the balancer shaft( the part that the crank slides into and touches)is broken off. I cant see clearly but im hoping that the Screw that hold the balancer on didn't brake off in the crank . If it did Brake of in the crank how do i go about getting it out and where can i get another balancer screw. I found the balancer in stores for aslow a $99, but can't seem to find the screw. So my Question is where can i order or find this screw, and is there anywhere i can get the balancer cheaper?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 30, 2004
  • Apr 30, 2004
I got my balancer for just under $60 shipped on ebay, new. If the bolt broke off in the crank, then hopefully the threads arent messed up and you can use an Easy-Out on it. The bolts should be available from the Ford parts counter or through a retailer that has a decent selection of ARP fasteners, like Summit or Jegs.
cevtv
1,113
Massachusetts
Apr 30, 2004
  • Apr 30, 2004
The stock replacement balancers are crap! They are only rated for 4,500RPM. Get a good one, and never worry about it again.
Here is the Balancer Bolt
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Apr 30, 2004
  • Apr 30, 2004
yep, my buddy put one on his car and its bad after 800 miles.
Legendary
1,925
City of Angels
Apr 30, 2004
  • Apr 30, 2004
What special tools are needed for this job?
Y
yelbigbirdlow
71
DFW Texas
May 13, 2004
  • May 13, 2004
HELP FIX MY CAR
upon further inspection i have found that the balancer bolt is infact broken off in the crank . i am wandering if the bold is a revers thread bolt and what level of difficulty should i expect as far as tring to get this broken bolt out? also what tools will i need to do this project. Last im not tring to spent alot on this project so what would be a good balancer for a desent price.
Legendary
1,925
City of Angels
May 13, 2004
  • May 13, 2004
Well I will be helping with this project. What tools would be need to put the new balancer on? Any tips or tricks to make things easy? Should we torque the bolt as much as we can or is there a specific number? Thanks for any help.
W
wisconsinboy
78
eau claire wisconsin
May 13, 2004
  • May 13, 2004
probly have to tap it. i got my new balencer from a junkyard for 30 bucks.
Rick 91GT
Mustang Master
95
99
PA
May 13, 2004
  • May 13, 2004
If you can get it out with an ez out it would be best, you need a drill (drill bit sized accordingly to the proper size for the bolt and ez out) you may need to put a little heat on the bolt as well.
That are a standard thread turn the BOLT counter clockwise to unbolt it, torque the bolt to 70-90ftlbs when finished. Put a little oil on the crank before installing the balancer, alos put some oil on the front timing cover seal (I'd suggest replacing the front seal since it is all apart, less then $10 at your local parts store) You should use a dampner install tool, so you don't pull on the threads of the crank, a new bolt is only a phone call away, the ARP works fine.
Inspect the front cover for cracks, depending on how the balancer came off it may have cracked the cover, or anything else that it may have hit when flying off, radiaitor, oil pan, etc...
Brian @ www.adperformance.com can get you a SFI Pioneer for around $175, they are nice pieces. I wouldn't put a stock or used balancer on anything....
Y
yelbigbirdlow
71
DFW Texas
May 14, 2004
#10
  • May 14, 2004
  • #10
Last night i took off my front bumper and my radiator. So i have a clear straight line of sight of the broken bolt in the crank. Today im going to try and get the bolt out. I have a couple of friends who are going to come over and help me out. I was wondering if anyone has had this same problem of a broken balancer bolt in their crank. if so what did you do to get it out and how hard was it. Im planing to use an easy-out.
W
wisconsinboy
78
May 14, 2004
#11
  • May 14, 2004
  • #11
i had a snapped bolt in one of my heads. couldnt use a ez out cause it didnt work so i just drilled and tapped it. if you got the right size tap and thread it right itll just tap out the bolt.
BarnStang
1,260
Hagerstown, MD
May 14, 2004
#12
  • May 14, 2004
  • #12
Did the bolt break off flush with the end of the crank or is it broken off inside? If its flush, that bolt should be large enough to see if you can get it to rotate out with a punch. This would be a gentle procedure not a reckless one. If it won't budge, then drill a hole in it and use an easy out. The biggest one you can get in there so the easy out doesn't break off in the bolt. Cause then you will have problems...
It will probably be easier to work on if you pull the radiator. Also less risk of gouging the radiator by mistake.
Y
yelbigbirdlow
71
DFW Texas
May 14, 2004
#13
  • May 14, 2004
  • #13
the bolt broke off in the crank down to the point where i can see part of two lines of thread in the crank.
Rick 91GT
Mustang Master
95
99
PA
May 14, 2004
#14
  • May 14, 2004
  • #14
I'd start soaking it in penetrating lube, liquid wrench, PB blaster etc... your going to need it. Just make sure with the ez out you drill the hole dead center, use a center drill bit if you have access to one, then use the required size.
HO93LX302
715
Naugatuck,CT
May 14, 2004
#15
  • May 14, 2004
  • #15
I had that problem with my balancer.. but it blew completely off, snapping the crank bolt leaving half of it in the crank.. the balancer went right threw the radiator.. what a mess let me tell you.. you don't need a ez out.. all i used was a left handed dril bit and cordless drill.. put the drill on reverse and it caught a part of the bolt and unthreaded it out.. remember theres no torque on the bolt since its broke so if you go to drill a hole in it, it may thread in more.. 720-7847 thats the part number for the crank bolt i bought from JEGS... its a grade 8 mr. gasket bolt... only $10... it install the balancer just line up the key ways and tap the balancer on gently.. then thread the bolt on and tighten it, it will go on the crank the rest of the way when you tighten the bolt.. good luck
Y
yelbigbirdlow
71
DFW Texas
May 14, 2004
#16
  • May 14, 2004
  • #16
HEy HO93LX302 what size left handed drill bit did you use?
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
