  • 1994 - 1995 Specific Tech
balancer question
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Oct 27, 2005
9
95mustang_gt
364
Wisconsin
Oct 27, 2005
  • Oct 27, 2005
Well so far i have i have the fan off for more room and i took off the crankshaft pulley.I just cant take that bolt off in the middle because the balancer will turn with it.
What did you guys use to get the balancer still and loosen the middle bolt?
FORCED2DV8
458
Grand Rapids MI
Oct 27, 2005
  • Oct 27, 2005
impact air gun, or take out spark plug on no1 cylinder and put a piece of rope in it / rotate engine until no 1 comes to the top, the rope with stop the piston from making its full rotation because it fills the combustion chamber, loosten the bolt, after words slowly rotate engine back the other direction enough to remove the rope, thats what i do, some people will freak out about it, but i have done it hundreds of times, never had a problem.
W
Westee
36
  • Oct 27, 2005
If you're replacing the balancer, you seriously need to think about renting/buying a puller from the local auto parts store...
9
95mustang_gt
364
Wisconsin
Oct 27, 2005
  • Oct 27, 2005
I did that yesterday.
W
Westee
36
  • Oct 27, 2005
I changed mine about 2 months ago...I had no problems getting the center bolt out. I held the balancer while my dad turned the wrench...Do you have anyone to help you out? Honestly, I had a tougher time getting the center bolt back in....
H
highhorseb
226
Finksburg, Maryland
Oct 27, 2005
  • Oct 27, 2005
Put the car in 5th gear, chock the wheels, pull the Ebrake then turn the bolt. The drivetrain will hold the balancer in place while you break the bolt loose.
a50sn95
368
Elk Grove, CA
Oct 27, 2005
  • Oct 27, 2005
Worked for me, but won't in this case...
As long as you have a 5-speed...
HISSIN50
34
129
Oct 27, 2005
  • Oct 27, 2005
Impact.
A local shop could blap it loose. You could tighten it enough to safely get home and then remove it.
Good luck.
9
95mustang_gt
364
Wisconsin
Oct 28, 2005
  • Oct 28, 2005
i got it done,it took a while,but i got it.I put the new balancer on and the rpms if so much smoother.I got a romac.
thanks for the help everyone
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
2001 GT stuck in 2nd
  • 01gtslider
  • Jul 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
01gtslider
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
